Author Topic: Where did you mount your Fuzeblock? (2010+)  (Read 4994 times)
Offline udoggie
« on: September 22, 2012, 09:51:19 PM »
I'm wondering where people are mounting their Fuzeblock.
The "toolbox" under the seat is just too far from everything I want to power (almost all up front)
I've removed the right-side fairing cover, and have been eyeing mounting it to the bracket that supports the baffle.
Any suggestions?  Pictures would really help too!
Thanks,
UD
Aloha, OR.
Re: Where did you mount your Fuzeblock? (2010+)
« Reply #1 on: September 22, 2012, 10:40:54 PM »
 :popcorn:
Offline vortex2
« Reply #2 on: September 28, 2012, 02:14:24 AM »
Inside the right upper fairing, remove the black piece and mount it on the foam baffle. Fits perfectly.
Offline MikeERideWNC
« Reply #3 on: September 28, 2012, 08:33:28 PM »
Put your tool kit in the cubby on the bottom of your Sargent's seat.
Then pull out the box which held your tool kit.
The fuse block can mount to one of the bolt holes and has plenty of room to grow.
Well, that is what I did.
« Reply #4 on: September 28, 2012, 10:48:21 PM »
Total best place IMHO, taking the chance of getting wet anyplace else.
Offline jjsC6
« Reply #5 on: September 29, 2012, 06:05:22 AM »
That is where mine is.....
Jim
2010 Concours - Sold Feb 2013
Current bikes....
Offline udoggie
« Reply #6 on: September 29, 2012, 07:10:11 AM »
Thanks for the feedback everyone!  I've decided to go with the right side baffle as well.  It is the closest to where most of the farkles that need power will be located, and the cover should be enough to protect it, it's just 12v.
Again, thank you!   :chugbeer: :chugbeer: :chugbeer:
UD
Aloha, OR.
« Reply #7 on: September 29, 2012, 07:56:57 AM »
So if you go with that position instead of under ths seat, you now have another question which needs to be answered...
How dificult is it to change out a fuse when I am traveling?
The right panel has three hex screws and one plastic rivet behind the windshield.
Under the seat, has one motorcycle key.
Offline udoggie
« Reply #8 on: September 29, 2012, 08:55:46 AM »
True, this is something to be considered.
I have all the tools needed to replace a fuse though, under the seat :-)
Plus, how many times have you had to actually change a fuse when on the road?
Nothing plugged into the fuzeblock is essential to being able to ride.
To me at least, it seems like an acceptable location.  To each their own, I guess though.
UD
Aloha, OR.
Offline jjsC6
« Reply #9 on: September 29, 2012, 03:26:46 PM »
I can have that panel off in about two minutes.  For getting to a fuse you can probably leave the rivet under the windshield on and just tilt it up, although I admit I have not actually tried it.  With the right screwdriver you can get that rivet off without pulling the windshield off - I've done it several times.
I do like that you are thinking of pros and cons though!
Jim
Current bikes....
« Reply #10 on: September 30, 2012, 06:33:40 PM »
^^^^^^^^^^^^that
Offline Highett
« Reply #11 on: November 10, 2012, 04:23:10 PM »
ZG1400CBF (2011)
I Mounted Fuzeblock inside the upper right side fairing.
Battery Connection:
Front and rear power cable from battery:
Front cable placement:
Fuzeblock Mounting Bracket:
Fuzeblock Bracket Placement:
Fuzeblock fitted:
Wired up, included driving light relay:
Right side cover back in place:
Cheers
« Reply #12 on: November 10, 2012, 07:52:29 PM »
Gonna have to say you're a little tie wrap happy,  clean install though. Nice write-up on your install, thanks.
Offline C1xRider
« Reply #13 on: November 11, 2012, 09:39:47 AM »
Very clean install, nice work!
Liking that green too.  It's almost as sweet as the blue ones.   ;)  :)
Offline Smokeyzx
« Reply #14 on: November 11, 2012, 10:31:33 AM »
Nice installs.
I took the tool kit out and mounted the Fuzeblock under the Corbin passenger seat for quick access. I'd post a pic but looks like a rats nest in there right now...
Colorado
2013 Blue
« Reply #15 on: November 11, 2012, 09:05:57 PM »
My install:
