Author Topic: My HOT BOX fix!!  (Read 7227 times)
Offline Xelvic
Re: My HOT BOX fix!!
« Reply #20 on: September 11, 2012, 03:56:21 PM »
This is what I used. It comes in different sizes. http://www.jegs.com/i/Thermo+Tec/893/14610/10002/-1
2012 Kawasaki Concours 14
Offline Armyguns
« Reply #21 on: September 11, 2012, 04:08:48 PM »
I would bet it gets around 150 degrees in there.
68deg F air temp here in NJ today.  40 mile ride home from work.  127deg F inside the box with my IR thermometer against the back wall (closest to the grip heat control knob on the 2010).  112 F on the front inside wall.  I know it gets hotter as the air temp increases.  I keep a Kryptonite rotor lock in there all the time. This is a big heat-sink.  It has been so hot that I could not hold it in my bare hands, but I had not actually measured it.
2010 C14 ABS
