Author Topic: Tire Pressure sensor replacement?  (Read 22521 times)
Re: Tire Pressure sensor replacement?
« Reply #20 on: August 20, 2012, 08:09:27 PM »
Oh, just get him liquored up and he'll be alright.
« Reply #21 on: August 20, 2012, 08:11:26 PM »
No but if the entire TPS signal is lost, the display simply displays '---' where the pressure should be. The easiest way I know of to do that is to cut one leg of the battery power in the seniors. That renders the sensor totally inoperative and while it will no longer report tire pressure, the system will then not show any kind of error either.
I think the entire TPS system is beneficial enough to be worth changing batteries every few years but that is just my opinion. Of course 'changing batteries' means cutting and soldering new ones in as the sensors were never meant to have replaceable batteries in the first place. It is simply too expensive to replace the whole sensor just because the battery has worn out.
How do you intend to eliminate the sensors? I imagine it wouldn't be too difficult to get stems back in there, but I'm wondering if you can fool the ECU to think the sensors are fine.
« Reply #22 on: August 20, 2012, 09:23:29 PM »
What are yours doing that is bad?  Perhaps I missed another post somewhere...
I haven't done anything that is bad, the stupid ass dealer wanted me to leave my bike there at the dealer, and there was still no guarantee that Kwak would replace them. This was while still under warranty, and now the warranty is up. This bike has been 100% flawless, just the sensors that are wearing out now. I have no issue with the "-" being on the dash, I understand there will be no red light if the ECU doesn't even see them. Yeah the sensors are nice if they work, but I have owned no bike that ever had them until now.....so I won't miss them any.
« Reply #23 on: August 20, 2012, 09:25:59 PM »
Brian.....if I were to buy the 90 degree stems form Murph, can I take out the sensors and just use these instead? Do these just go through the rim and then seal from the top and a nut tightens from the bottom?
Or I am thinking of going with these instead, pretty sure these will be a direct replacement?  http://kurveygirl.com/shop/product_info.php?products_id=144
Offline scootertrash
« Reply #24 on: August 20, 2012, 10:14:21 PM »
 :o I bought the land shark(silverish 08 c14) from the second owner in pristine condition with 5700 miles in november, 2011. After recovering from malaria the guy gave me( flu) while coughing, I go out to play with my new toy, and theres this warning" tps battery low" stupidly blinking on the display like i missed it the first 3000 times it's blinked at me already.
So I quickly waist the continental tires that r on it by shreading in the hill's,  so I can fix the sensors( no warrenty) and mount my new Q-2 dunlop's.
The dealer says no warranty, and there 200 buck each, and both r bad now. I dismount ties( bike looks like a ship in drydock), take sensors apart, pry the spot welds off the batteries, go to batteries plus, buy 2 standard watch/camera batt's. and the guy there solder's them in place for me. Had to do this twice because u need good battery placement to re assemble it.
So b4 i go , I use meter to check batt. voltage, and they lost 50% of there charge from the solder heat. The guy didnt even charge me 4 second batt's. These in place, I install, mount tires, and "BAM", working tps sensors for like 10 bucks( 4.75 per batt, no labor charge-awesome)
They last 30 days and fail. ****. I cal;l dealer( good times kawasaki in sacramento). She say's( I think Laura) "I will call kawi and see if they will good faith warranty the tps's. since so many have failed so quickly and repeatedly". I think ya, right. Wonderwoman calls me a few days later, kawi will change um for "free", including r&r, mount/balance,etc. Can u say wow?
I drop the bike, they call me later, and BAM, working tps sensors this time for free. Shocker, yes?
A true story.
« Reply #25 on: August 21, 2012, 08:38:05 AM »
I don't know- I do not have those 90 degree adapters?
The as far as just the valve stem (stock or otherwise) the only thing the sensor really does is provide a spacer to load the spring. You <may> be able to just crank the stem farther enough in to compensate for it but I don't think so. You could also find a piece of tubing (metal or plastic) of around the right ID (not critical) and cut a piece to act as the sensor. That is probably the easiest thing to do- just use a sleeve of something to space the spring out- take the stem to Home- Lowes and walk through the plumbing aisle until you find something that fits.
As to the other stem adapters, again I just don't know if they will fit the wheel or not.
Best of luck with it.
Offline C1xRider
« Reply #26 on: August 21, 2012, 10:17:16 AM »
This sounds more like a dealer issue (been there).  Even out of warranty, if the problem was reported while under warranty, Kwak will likely cover fixing it.  You should call them directly (bypass the crappy dealer), and when you are ready for new tires, get a free mounting and balancing as well.
You can use the same valve stem you have now (or the Murphs 90 degree style).  The sensors "float" over the inside portion of the valve stems, with a spring to hold them against the wheels.
« Reply #27 on: August 21, 2012, 07:15:13 PM »
I am done playing paddy cake with the dealer, I am going to give the 90 degree stems I listed a try. 8)
Offline Burbs
  • 2009 ABS
« Reply #28 on: February 27, 2015, 03:24:20 PM »
Brian, is this confirmed that if one leg is cut, there won't be any error messages? I'm having new tires put on and my rear sensor battery is dying so I just want the guy to snip it if this solution works. The front one is already dead, so I'm good there.
Chris
« Reply #29 on: February 27, 2015, 03:51:32 PM »
Holy thread resurrection, Batman!    ;D
Yes. Without power to the TPS, there will be no warning.
To cut a battery leg, the TPS must be taken apart though.
Chris
« Reply #30 on: February 27, 2015, 05:05:38 PM »
I give him a gold star for great searching and thread-reduction abilities!
« Reply #31 on: February 27, 2015, 08:14:04 PM »
 8)   Geez, you nearly burned my eyes out with that, Max!
« Reply #32 on: February 28, 2015, 06:07:29 AM »
I beg to differ. The easiest way is to just let the batteries go dead on their own.   ;D
Offline texrider
« Reply #33 on: February 28, 2015, 06:32:38 AM »
I never bothered to solder in the replacement batteries, just put a new one in each sensor at every tire change. That way they always work, and aren't sensitive to low temps.
The sensors themselves seem to be sturdy enough.  8)
2014 Valkyrie
Offline Burbs
  • 2009 ABS
« Reply #34 on: February 28, 2015, 06:35:12 AM »
Last thing I wanted to do is start another thread on this subject.  ;)
If you want, I can start an oil or tire thread!!!!  :1DeadBanana
Brian (or anyone else that can answer this) what does "taking it apart" involve?
Chris
« Reply #35 on: February 28, 2015, 06:54:38 AM »
http://www.zggtr.org/index.php?topic=16850.0    Tires or sensors?
Offline Burbs
  • 2009 ABS
« Reply #36 on: February 28, 2015, 07:55:42 AM »
Thanks Maxtog, that answers my question.
Chris
Offline Stavee
« Reply #37 on: February 28, 2015, 05:29:24 PM »
Off topic.  Brian How are you?  Have you done any sea to sea runs lately?
First bike '38 DKW
« Reply #38 on: February 28, 2015, 06:46:13 PM »
On the topic of TPS battery replacement: It seems like the replacement batteries I put in in 2013 are holding up better than the originals. Looks like I will get through two winters without any warnings and I have been riding in plenty of low 40 f temps this winter. Iirc, the oems started acting up early the 2nd winter  (08/09) at anything below 55. Maybe better batteries or maybe just fresher.
« Reply #39 on: February 28, 2015, 11:14:25 PM »
Excellent, how are you doing Ralph?
Nope, last time was a west / east try that had me stopping by to visit the cardiac unit of a hospital in PA. I was w/in 150 miles of Rye, NY WHEN SUDDENLY, things were not going well to say the least. I guess I did a CC100 w/ stress test and an overnight in a really slick electric bed but there is no slot for that in the IBA. :-)  Betcha' I am the only guy in the US who ever ran the treadmill wearing heated motorcycle boots....
