Author Topic: Cracked coil casing  (Read 2169 times)
Offline Pfloydgad
Cracked coil casing
« on: August 18, 2012, 07:12:53 AM »
OK,
I'm doing a valve adjust, and there it is, a cracked coil casing. about 2" long ways and then some down the side. Still works and is not shorting. Years ago I used a 2 part epoxy on some Wing coils for the same reason, they are still on the bike and working fine.
So the $5 question is this, being a Connie, can I do the same with this coil?
Your input is required, as its 72 degrees and sunny here in Ohio this morning.
Thanks all, and ride safe out there.
Greg
Offline JDM
Re: Cracked coil casing
« Reply #1 on: August 18, 2012, 07:43:53 AM »
I would sure as hell do it.  I am to cheep not to. JD
Offline T Cro ®
« Reply #2 on: August 18, 2012, 08:44:01 AM »
JB-Weld has solved many a problems......
Ultamitely I can hook you up with the fashionable fix.... LOL See my sig line.
Tony P. Crochet
Offline Pfloydgad
« Reply #3 on: August 18, 2012, 09:13:11 AM »
I know it is a case to basically keep moisture out, so the epoxy went on, and it sealed it all up, nice and tight.
T, I will be doinf your stick coils over the winter break, so get som built.
Thanks for the input,
RSA, greg
Offline T Cro ®
« Reply #4 on: August 18, 2012, 09:30:44 AM »
T, I will be doing your stick coils over the winter break, so get som built.
Look in the backgound on the workbench..... See all the USPS-PM boxes? I got ya covered!
Tony P. Crochet
Offline julianop
« Reply #5 on: August 19, 2012, 12:01:19 PM »
Forgive the bust-in on this thread, but Tony, could you please point me at a source for those aux light brackets? I use the Hella FF50's too, and like your mounting better than mine. Actually, I want to add a couple of their fog beam FF-50's too, so could you advise on a source for a low-mount mounting bracket (brake caliper, maybe?) for those.
Thanks.
Julian.
Elk River, MN.
Seasonal Temporal Navigational Disorder - that inexplicable but wholly satisfying affliction that causes one to lose the ability to drive a motorcycle straight home after work in the summer months, despite the apparent ability to make the reverse journey that same morning.
Offline throb
« Reply #6 on: August 19, 2012, 06:35:56 PM »
http://www.zggtr.org/index.php?topic=6794.msg88355#msg88355
  Talk to Snarf, he makes them along with block off plates.  Having a set of each, I can attest to their top notch quality!
Offline mdr
    • Mark in Austin's C10 Tech Page
« Reply #7 on: August 23, 2012, 07:25:48 PM »
If you've done it before you know the drill, but here's how the V-Dubbers do it.
http://www.randols.net/VW/coilpack.htm
Also, may want to 'bake' it to drive out any moisture in it before sealing it up.  Lowest temp available, while she's out of town ;)
Mark in Austin
'01 Concours, Vrooomm
My "Tech Page"
http://www.randols.net/Connie/index.html
