Mine broke internally right where it attaches to the front hub.I found a cheap basin wrench a few years back it works pert darn good for tightening the top nut. Just pivot the head 90* and get'r done
Boy, is it ever hard to tighten it up well at the speedometer end, at leasat for me it was.
I took the cable off at the wheel and the cable is broke about 2 inches from the wheel. Thanks for your help.Thats easy...Just pretend that you DONT need it and look around for something else. That is the only sure-fire way to find a tool. Cause if you need it you are not going to find it.
I couldnt get to the end at the gauge, hand just wouldnt fit. That's a great idea about the basin wrench. i have one somewhere just have to find it. Have not seen it in years...
Thats easy...Just pretend that you DONT need it and look around for something else. That is the only sure-fire way to find a tool. Cause if you need it you are not going to find it.I always seem to find my tools within a week of purchasing the replacement tool. I'll have to try your method as it appears to be
I was talking about the steel loop on the forks under the headlight. Oops.
