Author Topic: Temporary Gas smell  (Read 5052 times)
YoDoc
Temporary Gas smell
« on: May 25, 2011, 11:18:36 AM »
Every time I shut off my bike, it smells like gas for about 10 minutes. i.e. if I leave the garage door open for ten minutes after I park the bike, no smell, but if I shut the door right away, it smells like gas for hours!
I can not find any leak anywhere. Is this something that carburetor bikes just do?
Offline Pfloydgad
Re: Temporary Gas smell
« Reply #1 on: May 25, 2011, 12:34:04 PM »
I will get that sometimes also, but I am sure mine is coming from expansion of the tank. I notice it on warm days and when you park the heat from the motor will cause a small amount of expansion that vents out of the cap. Next time try to take a wiff of air around the cap, and then down arond the carbs, you will probably be getting it from the cap.
Good luck.
Ride saf all.
Greg
Offline Ron Dawg
  • a/k/a ron203
« Reply #2 on: May 25, 2011, 01:10:49 PM »
The gas cap will "whistle" too. Open the cap and it stops. I've noticed particularly after a hot ride and I've filled up just before I parked.
2014 C-14 Red
Offline Jet
  • Dark Side of the Moon
« Reply #3 on: May 25, 2011, 01:48:53 PM »
I have the same issue, I just park it outside and let it cool off then wheel it into the garage.
...and a good time was had by all.
Offline RFH87_Connie
« Reply #4 on: May 25, 2011, 01:55:14 PM »
Do not lay your jacket or helmet across the tank, you'll smell gas for a week on them.
Offline Jet
« Reply #5 on: May 25, 2011, 02:24:07 PM »
But it gives me such a nice buzzzzzzz
Offline Ron Dawg
  • a/k/a ron203
« Reply #6 on: May 25, 2011, 07:38:06 PM »
Probably cures smoking, too. ;)
2014 C-14 Red
YoDoc
« Reply #7 on: May 26, 2011, 10:07:21 AM »
Outstanding. I'm glad I don't have anything to worry about. This is the first time I've ever owned a carbureted bike in years, and certainly the first time I've owned one with four!
Offline Cholla
« Reply #8 on: May 26, 2011, 11:35:50 AM »
Try Beano....LOL
+1 to above posts.
Offline red2000
« Reply #9 on: May 27, 2011, 07:47:13 AM »
I had this problem earlier this spring when I first started riding again after winter.  My milage was also lower than usual.  I was going through a prep. and clean up session while my tires were being mounted and discovered I had a small split in my fuel line right at the petcock.  I think it was leaking there while the bike was running and gas was flowing.  When I stopped it would quit leaking so it was hard to detect leak but there was still the smell of gas.  Might be worth looking at.
Todd
YoDoc
« Reply #10 on: May 27, 2011, 10:25:16 AM »
I'm gonna check on that. What's low? I've only run one tank through, and I got 40.3 mpg.
Offline Jet
« Reply #11 on: May 27, 2011, 12:41:19 PM »
40.3 isn't bad.  if you watch a bunch of guys have added the fuelly link to their posts, anywhere from 37 to 43 is what I'm seeing on most bikes, and depending on how hard I hit the throttle i bounce around in there a lot.
Offline ATC Buckeye
« Reply #12 on: June 28, 2011, 06:22:55 AM »
I get this too.  Some gas smell, and whistling through the gas cap.  Especially with a hot, full tank.
Offline gpzrocker
« Reply #13 on: June 28, 2011, 02:25:49 PM »
Friend with an 07 ZX-14 has a serious whistle going on when hot and a full tank: seems to be a norm.
