Kawasaki Concours Forum
Welcome,
Guest
. Please
login
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Calendar
Login
The C10, aka Kawasaki Concours - The Original
Accessories and Modifications - C10
(Moderator:
George R. Young
Shinko Journey tire pressure thread
« previous
next »
Print
Go Down
Author
Topic: Shinko Journey tire pressure thread (Read 2872 times)
gpzrocker
Full Member
on:
August 10, 2012, 04:05:38 PM »
What pressures are you running on the rear? I am down to about 36PSI and like it well there: for me higher really make the road irregularities harsh. Started at what I ran the Avon at, 40 or 42.
Front is the 011 and is nice at 40, but I might drop it down too.
And I am really liking this tire.
Logged
Daytona_Mike
Arena
Full Member
Country:
Re: Shinko Journey tire pressure thread
Reply #1 on:
August 10, 2012, 05:02:13 PM »
Your tire pressure is too low and will result in the tire overheating. I know this because I have a tire pressure monitor system and also tell me the tire temperature. The rear needs to be at least 41 to 42. The front needs to be 40. This is when the tire is cold. When your out riding it will rise to about 45-46. The funny thing is when you have less air the tire gets even hotter and the pressure will rise from 38 to 48 or more.
Logged
snarf
Arena
Full Member
Country:
Reply #2 on:
August 10, 2012, 09:13:01 PM »
+1 I run 40f 42r
Logged
2002 Conc
1986 Conc "The spirit of COG"
George R. Young
Moderator
Full Member
Country:
Reply #3 on:
August 11, 2012, 07:33:20 AM »
This fellow
http://www.motorcyclespecs.co.za/Techinicale/tire_pressure.htm
says to find a front/back cold pressure which give a 10%/20% pressure rise after riding.
FYI, I'm currently running 36/38 psi in a Michelin PR2/Commander setup.
Logged
Daytona_Mike
Arena
Full Member
Country:
Reply #4 on:
August 11, 2012, 08:21:44 AM »
Thanks George.. good write up. I was using the 10% rule for the front and rear tire. The last rear tire I just installed is a super grippy sport tire and it runs hot. I had to put 44lbs in it to keep it from getting too hot. Now I know I have a 20% variant which is normal for the rear.
If I run anything less than 40 in the front it gets too hot and scallops. I do run my forks a little lower in the triple tree to get some more weight forward so that might be a factor.
Logged
gpzrocker
Full Member
Reply #5 on:
August 12, 2012, 08:05:03 AM »
Ok guys, went out and reinflated my tire back up. Thinking about it I realized that with my weight loss (30 lbs in 3 months) I may need to revisit my shock settings to get a more comfortable ride.
Thanks for setting me straight on the tire pressures.
Logged
Pfloydgad
Full Member
Country:
When I was a child, I caught a fleeting glimpse
Reply #6 on:
August 16, 2012, 05:00:31 PM »
7500 miles on mine so far, and 42 PSi. tread looks great, and it still has rolling edges. This is my fav. tire, I am getting another one just because, not o put on right now, but when needed.
RSA,
Greg
Logged
Print
Go Up
« previous
next »
(Moderator:
George R. Young
