Got the new realys, my ground connection was redone when I installed Tony's stick coils so that was good and tight. Replaced the relays, when trying to de-solder an item it's helpful to add new solder to the joint, then it becomes molten easier and you can use a solder-pullet to suck the solder out of the connection. Installed the relays, did resolder a number of the connections, a word of caution, when you are heating up the fuse holder bits they will come out of alignment, making putting the cover on a bit harder. Fired the old girl up and everything is nicely working as it should be.
