Author Topic: New multi-adjustable handlebars from Precision Engineering  (Read 49878 times)
As much as it detract from such a beautiful bike, really really really need a picture of you on the bike holding the bars  8)
NO!!!!  :yikes:  ZG can you get your wife to sit on the bike and hold the bars?   :stirpot: :popcorn:
Offline wally_games
I would be satisfied with a lot less adjustability, as long as I could swing the grips outward just a little to reduce the twisting strain on my wrists that I believe to be the main cause of pain/numbness.
These do look pretty good to me, except for the way the extension sections look when they're pulled out. That little series of holes and the silver Allen head screws are just plain distracting. Couldn't they have put them on the underneath side and more out of sight?
Like this?  ;D ;)
Like this?  ;D ;)
He said YOUR wife, not mine ;D
Offline Glennn
    • Metric Rider
Holy ****, your wife was at my place last night?!
2012 Midnight Sapphire Blue 1400GTR
1999 Yamaha Road Star
Canberra, Australia
CDA #390
She left early, something about a "Minute Man"? ;D
Offline Necron99
    • Facebook Page
Yeah, she said, "Who you going to please with THAT?"  And I said, "ME!"
Do not go gentle into that good night.
-Dylan Thomas
2010 ZG1400 COG #9384
Offline Glennn
    • Metric Rider
A minute, you give me too much credit  ;D
Sorry for derailing your thread, ZG  ::)
Canberra, Australia
CDA #390
Thanks for the additional photos.  Question.  If you only needed one fastener to hold the bars in place then why are the holes going all the way around the base?
Looks like the design is still in some flux.  Do I jump on them or wait for gen 2.  Mmm.
The holes on the arm are not symmetrical, only the holes on the bases are. The small bolt that you see can be placed in any of the holes, hence the adjustment points. The holes in the bases are just holes, but the holes in the arms (that the small bolt threads into) are tapped, so it was easier for PE to just drill a hole in the base for me rather than adding and additional tapped hole. Make sense??
Well, I'd think the current ZG $150 discount is worth pulling the trigger, the discount only goes for another 3 weeks...
I know I'm happy.  :)
Just ordered a set of these bars.  Going to mount them without risers and my goal is to bring them closer and turn them in a little.  I thing I need to find the optimum handlebar position before I try seat options.
I sat on a friends Concours with a Corbin seat and for the me the seat made me want to have the bars back at least 6 inches because the seat position is so upright.
I like the forward lean of the stock seat.  The foam is just too soft for distance riding IMO.
Offline Glennn
    • Metric Rider
This.
I am really agonising over getting something.  I was noticing the angle of my arm to my hand the other day while riding, and my arm defeinitly pokes out at the elbow like a chicken wing (to overexagerate).  I went down and sat on the bike bike tonight, assumed the position as it were, and could really see how this outward twist in my arm extends down to put weight on the outer edge of my palm.  I also noticed that if I pretended I was braking hard into a corner (work with me here, guys), the angle of my arm twisting out was even more pronounced and I could feel this leverage effect putting even more weight on the outer edge of my palm - this I am going to assume is where my nerve damage came from that is still not 100% healed.  When I straight armed myself, so there was a straight line down my arm over my hand, I could feel my weight evenly distrubted over my palm and even pretending to brake hard while my arm still chicken wings slightly, it is no where near as pronounced and the weight stays mostly across my palm.
I am personally convinced unless I do something like these risers that will twist the grip outwards I will have to sell the bike as it would seem a day of hard riding in the twisties leaves me a cripple (or at least having the pleasure of a stranger doing it (if you have to ask, you don't want to know)).
GAH! I really wanted some exhausts, but these "practical" mods keep getting in the way. I'll have to ask if they post to Australia.
Canberra, Australia
CDA #390
Glennn,
You did make motor noises while you were doing all that right? If not, get back out there and try it again!    ;)
Offline C1xRider
This.
I had the same problem with the palm to handlebar alignment.  A few months after buying my 2010, I went on a 3600 mile 9 day ride.  It took months to get the feeling back in the third finger of my right hand.
After chatting with Phil (of Phil's Farkles) about it, I installed a set of his (now Murphs) wedges, and that seems to have fixed the issue for me.  If funds are tight, that might be a acceptable solution too.
Offline wally_games
The wedges certainly helped, but did not completely solve the issue for me. I really wish someone just sold the round grip bars with a slight angle in them where they join the uprights (I calculated 6% for me). That would move the bar end weights towards the front of the bike slightly and would create an angle that would fit my palm much better.
(Might even make them out of something a little heavier to help with the vibrations.)
Phil??  ;)
Phil's (now Murph's) wedges are the cure for a lot of these types of hand problems.  I highly recommend them and I have them installed under my 2" risers.
Offline Glennn
    • Metric Rider
Yeah I've got both the risers and wedges, do help a little, but there is still an acute twist to my wrist.  Iffn I get these PE handlebars I'll keep the risers initially as they should work without extending the brake lines (reading what Jay has done for us), and twisting the handles out might also give enough slack to pull them back a notch too.
Canberra, Australia
CDA #390
Offline Glennn
    • Metric Rider
Holy snapping duck-poo their international shipping rates wipe out the discount.  Hopefully they will accept my freight forwarder address.
Canberra, Australia
CDA #390
Offline wally_games
Why wouldn't you remove the risers and just extend the new bars? Unless you were planning on extending them AND using risers to get them into ape-hanger territory.  :o
