Author Topic: Curiosity's incredible Mars landing 8/5/12 10:31 pm Pacific  (Read 10365 times)
« on: August 01, 2012, 10:51:54 AM »
http://science.nasa.gov/science-news/science-at-nasa/2012/30jul_skycrane/
July 30, 2012:  On August 5th at 10:31 p.m. Pacific Time, NASA will gently deposit their new, 2000-pound Curiosity rover on the surface of Mars, wheels-first and ready to roll. Quite a feat – because it will come screaming through the Martian atmosphere at 13,000 mph.
Curiosity, aka the Mars Science Laboratory, will be the largest mission ever to land on another planet. It's big because it has a big mystery to solve: was Mars ever or is it still capable of harboring life?
During its grand entrance, the lander must slow to 1 1/2 mph to touch down safely. That kind of braking action for a one-ton payload demands the nail-bitingly precise unfolding of an intricately choreographed sequence of events. Key players: a red-hot heat shield, a huge parachute, 76 explosive bolts -- and a Sky Crane.
7 Minutes of Terror: Curiosity Rover's Risky Mars Landing | Video
"The whole ballgame transpires within 7 minutes, from atmospheric entry to touch-down," says Jet Propulsion Laboratory's Steve Sell, Deputy Operations Lead for Entry, Descent, and Landing. "The onboard computer calls the shots. And if any one maneuver fails, it's game over."
Here's the game plan.
"Atmospheric friction slows the capsule containing Sky Crane -- an eight-rocket jetpack attached to the rover -- from 13000 to 1000 mph. [Mars' atmosphere is too thin to slow it more.] The friction burnishes the capsule's heat shield to a glowing 3800 degrees Fahrenheit (2100 degrees Celsius). Then a 60-foot diameter parachute deploys and inflates above the capsule on 160-foot lines. What's left of the heat shield jettisons, giving Curiosity its first look at its new home below."
This is the largest, strongest parachute ever flown to another world. It has to be a super-chute to handle the 65000 pounds of force produced when the rover snaps to attention below it.
"After the payload slows to about 200 mph, explosive bolts free the chute and Sky Crane free-falls for a second. Then its retrorockets fire."
The rockets slow the descent to 1 ½ mph and power a sideways parry to avoid the faster falling chute. As Sky Crane descends to 60 feet above Mars' surface, the rover inches down from underneath it on three nylon ropes like a spider spinning strands of its web. With Curiosity dangling 20 feet below, Sky Crane continues its downward progress until the rover is resting on the surface. Explosive bolts cut Curiosity's last physical attachments to the outside world, and Sky Crane flies away to death-plunge into the red sands, its incredible job done.
It might sound frighteningly complicated, "but what appears to be a complex system actually simplifies the landing greatly," explains Sell.
Previous missions such as Vikings I and II and the Mars Phoenix Lander used retrorockets to lower spacecraft all the way to the surface atop a legged lander. Others have used airbags. Neither method is feasible for Curiosity.
"With a payload this size, the rockets could kick up enough dust to compromise the rover and its instruments," explains Sell. "And the rockets could excavate craters Curiosity would have to avoid as it drives away. Add to that the risk of a big, heavy vehicle driving down off the lander via an exit ramp to reach the surface."
Pathfinder, Spirit, and Opportunity used airbags to eliminate these concerns. But Curiosity is too large for airbags.
"Bags big enough to soften its landing would be too heavy or too costly to launch. Besides, you'd have to drop the payload so slowly for the bags to survive the load, you may as well place the rover right on its wheels."
Three generations of Mars rovers. Curiosity (pictured right) is more massive than its predecessors, which is why NASA had to develop an innovative landing system.
Sky Crane, says Sell, makes sense for Curiosity. But it still keeps him up at night.
"I leave myself voicemails in the middle of the night about things to check in the morning. We've run thousands of tests and simulations, thinking of ways to 'break' the system so we can build in comfortable performance margins. We're still testing. There's always one more test we can run. We're always afraid we missed something."
In the control room at JPL the night of August 5th, it will be too late. It takes 14 minutes for signals to travel from Mars to Earth. When the team receives the signal 'I am entering the atmosphere,' Curiosity will be alive or dead on the surface.
Says Sell: "I'm already holding my breath."
Re: Curiosity's incredible Mars landing 8/5/12 10:31 pm Pacific
« Reply #1 on: August 01, 2012, 02:22:06 PM »
No good can come from this, methinks.   In the old days, we used balloons.  Darn new fangled Mars rovers, hogwash!
Hopefully we'll be able to know when it hits the surface.  Should be a big puff of dust, large enough to see via telescope I would think.  In looking at the animation and all the parts that have to work and wondering how the heck they tested this, I don't think it has a snowball's chance to survive.  I'm crossing my fingers, though.
« Last Edit: August 01, 2012, 03:03:00 PM by VirginiaJim »
« Reply #2 on: August 02, 2012, 04:57:50 AM »
That's the thing Jim. By lowering the lander to the surface with the sky crane, there shouldn't be any dust clouds.
Check it out on the Science Channel, they're running a special all about it.
http://science.discovery.com/tv-schedules/special.html?paid=48.15727.137576.43765.0
« Reply #3 on: August 02, 2012, 08:28:13 AM »
Wish I could, but Comcast took the SCI out of my lineup.  :banghead:
« Reply #4 on: August 02, 2012, 08:31:32 AM »
With the atmosphere so thin I would expect the dust to settle pretty quickly like on the moon. Also I remember watching some of the lift offs on the moon from the lunar rovers and don't remember any dust clouds. Why is it more of a problem on mars?
« Reply #5 on: August 02, 2012, 09:02:29 AM »
Dunno. Maybe since the lander plus the sky crane weigh so much that there's a LOT more thrust needed?
Did you watch the video? They talked about that and the rover can't have any dust on it.
« Reply #6 on: August 02, 2012, 09:13:59 AM »
Sounds logical. Also maybe even the very thin atmosphere is enough to make a difference.
Offline Cholla
« Reply #7 on: August 02, 2012, 11:58:39 AM »
I want to know who will be there filming the live coverage of the landing? Marvin?
« Reply #8 on: August 02, 2012, 12:24:21 PM »
I think that it's the duck's turn this time. What's going on with Porky anyway? Not that there's anything wrong with that... At least he'd got some pants on this time.
« Reply #9 on: August 02, 2012, 02:42:17 PM »
Actually, the puff of dust will be the lander hitting at 13000 mph.  What's the pool up to that it won't survive?
Offline snarf
« Reply #10 on: August 02, 2012, 02:49:29 PM »
Last I checked the bookies are giving 20-1 odds that one bolt will not explode sending the rig into the planet at a extreme high rate of speed.
2002 Conc
1986 Conc "The spirit of COG"
« Reply #11 on: August 02, 2012, 02:59:50 PM »
That will be the most expensive crater ever! $2.5 billion.
« Reply #12 on: August 02, 2012, 03:20:37 PM »
Great video, thanks.
« Reply #13 on: August 03, 2012, 09:58:47 AM »
The engineers at JPL are pretty bright. I think its going to be successful. Once the heat shield is off maybe they can get video of the decent and landing. I'd love to see that.
« Reply #14 on: August 03, 2012, 10:04:31 AM »
I agree Rhino. I think that it's going to work and that it's going to be amazing.
Offline Cholla
« Reply #15 on: August 04, 2012, 06:31:37 AM »
Who will be there to shoot the video from the planet surface?
« Reply #16 on: August 04, 2012, 06:55:33 AM »
That's the second time that you've asked that. What are you talking about exactly?
« Reply #17 on: August 04, 2012, 06:57:39 AM »
The moon landing was a fake too.
« Reply #18 on: August 04, 2012, 07:03:05 AM »
They lied to us? NO way!   ;)
« Reply #19 on: August 05, 2012, 10:38:38 AM »
Are you referring to my post regarding wanting to see a video of the descent? I was just wondering if a camera on Curiosity itself might be active while it is descending, after heat shield separation and if so we could eventually see the POV landing of Curiosity. Even if it is looking at the horizon or just up at the sky crane it would be very interesting.
