Decided to do the Overflow tubes Today, as it was easy and cheap. Like $4 for enough Brass Tube to do 5 sets of carbs. It is really easy for those who believe they are capable. There is a good write up here: http://web.ncf.ca/ag136/floatDrainTubes.htm by one of the members here.
I also set up the Float Bowls with different hardware, long Socket Head Cap Screws, 40mm, with a lock-nut/ washer that works like the Head of the Original screw. So once loosened the head works as a thumb wheel. So the bowls come off a lot easier if needed.
The 25" Clear View windshield I bought off of a member here showed up Today in the Mail, it's mounted but I will give it a ride tomorrow. Hopefully it will be better than the Stocker for wind around buffeting and noise around the Helmet. The Buffeting at 80+ was great from the stock shield. I'm over 6'.
Thanks MaD MiKe, but its not new. I'm just cheap, didn't want to pay $12.50 a screw for the ones they sell for the purpose. Might get them cheaper if you look.
I even looked at some different bowls altogether, but like I said, Cheap.
Like having a set of Tall valve Covers on your Hot Rod, and Solid Cam. Quick access long T Handle bolts would be a must.
well it looks like the Chain fr the Alternator is really loose and the tensioner is hitting the clutch.Most often it's the tensioner mechanism that fails and lets the chain flop around.
