Author Topic: What's The Diff---erence  (Read 4889 times)
Offline IraB
« on: September 21, 2013, 02:42:34 PM »
About to change the oil in the diff and wondering what most of you guys run.
Does anyone use good ol automotive grade 80w 90 gear oil?
Offline T Cro ®
Re: What's The Diff---erence
« Reply #1 on: September 21, 2013, 04:01:52 PM »
That's what's in there.... API GL-5 SAE 90
Tony P. Crochet
« Reply #2 on: September 21, 2013, 05:24:11 PM »
yep
it's just gears
Hypoid 80-90
unless you wanna spend uber bucks on some other synth-o-mesc version.... ::)
Offline IraB
« Reply #3 on: September 21, 2013, 06:54:47 PM »
yep
it's just gears
Hypoid 80-90
I think the synth stuff is probably a bit over rated and I know in some applications it is more prone to leak.
80w-90 it is then.
Offline Pilgrim
  • '12 Black
« Reply #4 on: September 22, 2013, 06:05:31 AM »
Does anyone know if marine lower unit gear oil, (which is GL-5, 80W-90) would be alright?
Offline T Cro ®
« Reply #5 on: September 22, 2013, 06:45:24 AM »
Fine.
Tony P. Crochet
enim57
« Reply #6 on: September 22, 2013, 06:46:33 PM »
I use Motul gear oil with molybdenum.
Regards, Russell
Offline Strawboss
« Reply #7 on: September 25, 2013, 10:02:05 AM »
I know a guy who once stuffed bananas into his final drive to quiet it so he could sell it. Long time ago.
Offline bbroj
  • To be determined...
« Reply #8 on: October 08, 2013, 07:34:37 PM »
Pet peeve of mine, Strawboss has it right. There is no Diff-erence, the bike has only a single drive wheel  :o It's a final drive, not a differential  ;D
COG 9331
Offline Pfloydgad
« Reply #9 on: November 06, 2013, 06:47:35 PM »
The last time I did the change, I was curious of the viscosity difference. I made a basic draw down scale on a piece of sheet metal, laid down the same amount of new and used, and used a draw down bar to see how they compared. New compared to old 6K  miles on the used. And there was no difference in the draw down. The only true diff I found was the viscosity weight. The used was 18% heavier by volume weight. Just a boring day the day I did this, not that it will help.
Ride safe all.
Greg
Offline IraB
« Reply #10 on: November 06, 2013, 06:54:52 PM »
Made time to change Kawazilla's final drive oil.  Looked like another thing the previous owner had been billed for that was not actually done.  It was obviously in bad need of changing and level was slightly low.
Fresh 80 w 90 in there now and I think it may go down the road a little quieter ...... or maybe I'm just believing that.
