The small leak was probably caused by too long of screws being installed in the lower fairing.
Be sure to tell them to use ONLY the correct length screws. in the bottom holes
It's pretty easy when you are removing the fairing screws to get these mixed up. Not all of them are the same length. I have a flat box I use with a bunch of holes punched in one side, in a 'matching pattern' to where the bolts come off of the fairing, which I insert the screws in as I remove them, to help me make sure that I put the screws back in the same hole I removed them from.
