....The pad on the center stand doesn't clear the left side mid pipe, so you need to make changes for things to fit. You can just extend the arm of the center stand around the pipe (what I did), remove the center stand (I would not), or buy a custom (like Muzzy's) modified center stand.Those things I am aware of, but does the mid pipe require any modification? Sorry if this sounds stupid but I have not started on mine yet and I have not been able to find any pictures depicting that area.
There's also no left side muffler mount location, so that requires a fix. Many go with the Muzzy's left bracket, so it looks (mostly) factory. I didn't........
Those things I am aware of, but does the mid pipe require any modification? Sorry if this sounds stupid but I have not started on mine yet and I have not been able to find any pictures depicting that area.I found the donut gasket where the mid connected to the header was thick enough to allow for slight manipulation of the midpipe to allow clearance around the hardparts. As C1x did, I modded the center stand to fit. The side stand contacted the mid slightly so I spotted a weld bead on the pad where the stand makes contact in the folded position. Went with Muzzy left side bracket.
WELCOME fellow East Texan! Kinda partial to that color myself! Hope to see you soon at some local gatherings.Hey Skip!! This is all your fault! Yours was the first I had ever seen in that color.
Mine didn't...
(from any manufacturer, really. I'm rather versed on the subject.)
Really? Your avatar and signature suggest otherwise. J/K Ryan, glad to see you are looking out for the new comers.
There are many of us here that would highly recommend the Canyon Cages and side bag protection from MCEnterprises.
........If you have any questions ....Great, Thanks! As a matter of fact I do have a question. Part #1400-410 is shown for the 2010-up only. Is that style of bar available for the 08-09's? I'm not a big fan of the #1400-100 I'm sure they would do a great job in the event of a tip over but I just can't see them without thinking of Ronald McDonalds shoes. I know, I know I have a strange way of thinking.
Wow! Much better, thanks.
You got rid of the cleanest Blue Pretty FJRs I've ever seen! Does this mean we are doing a CCS install this summer?Summer?! I already have the system, better make that early spring.
This is how you welcome people around here? Sheesh!Go back and look at the context of this picture. I was poking fun at Max.
