It should NOT go through the chrome brake line guide on the fork. It should only go through the plastic ring that snaps into the fender. Putting it through the brake line guide adds a curve to it that causes more wear on the cable.
That is good information, thanks
I replaced the OEM (I failed to tighten it to the back of the spedo at a previous maintenance, and it flopped out and I dragged it for a couple of miles before I noticed that this had happened, ground the ridges right off the end) with the Motion Pro from Murph's. It seemed a little more subtantial than the OEM, I guess time will tell.
