Author Topic: Sonic Springs and fork fluid level  (Read 2284 times)
Offline timsatx
« on: December 02, 2012, 09:43:00 AM »
I just noticed that the Sonic Springs instructions say that you check the oil with the forks collapsed and set at 150mm from the top, whereas the Concours manual using their springs say to check it fully extended and the level is at 171mm. After I put in the oil and then the springs with spacer I don't see an oil level. Is this cool?
