Yep, thought about all those things. Some of them are possible, some are not and mostly it is not feasible. Then again, given enough time and money a new instrument cluster could be built to display anything anyone wanted to but I suspect it would sell poorly.
I was originally planning on using a separate, remote warning in the form of a simple red LED that affixed somewhere on the dash. That way the bike would ignore the warning but the discreet LED would light when the 'low fuel' level was reached. The two basic problems with that method were cost and the fact that the remote LED would need to be wired onto the bike and a lot of people either cannot or do not want to do any dissemble, wire routing, possible drilling of holes, etc. This is the truly 'plug 'n play' version that can be added to the bike easily.
As to the other idea of displaying and removing the warning, it could be done but only sort of. There is a significant delay built into the system that cannot be overcome so if I sent the warning signal for, say, one second, the display would hold that warning mode for some time- something like one minute. And in addition to such a device not working the way I (and I think most others) would like, it would also be quiet expensive.
So like most of life, this is a compromise and a best effort for a reasonable adjustment, all in my opinion of course. It ain't perfect but it is workable, affordable and removes the biggest negatives without introducing any large negatives itself (again, in my opinion of course).
Great work Brian. Now, how about a newer improved model with a switch that allows the low fuel warning, then allows that to be switched off by hitting a button. ![Smiley :)](http://zggtr.org/Smileys/default/smiley.gif)
OOOOHHH what he said...I like it. ![Thumbs up! :thumbs:](http://zggtr.org/Smileys/default/fing02.gif)
Brian, I think you could sell a lot more of these! (Charge more too!
Good question but not sure that is possible. Will the bike revert to a normal condition if the "low fuel" alert line is removed AFTER is has signaled low fuel? Sounds like it might be the best of both worlds.
Although I like the idea a lot, I am not sure I want to COMPLETELY lose the low fuel warning. What I hate about the warning is that it is too difficult to remove while riding (having to press two buttons in perfect sequence ON THE DASH while MOVING is not easy nor safe- yet I do it every time). And of course, that it then stops the ability to use the miles remaining.
