Author Topic: Need help removing the front fender  (Read 27781 times)
Offline katata1100
« on: June 10, 2011, 03:43:01 PM »
It looks pretty straightforward, but how do you remove the plastic loops that the brake hoses go through?
Re: Need help removing the front fender
« Reply #1 on: June 10, 2011, 03:44:05 PM »
Try a set of long needle-nose, why you need to take off the fender?
Bob
« Reply #2 on: June 10, 2011, 04:17:07 PM »
I just cut them off and put new ones on for a few bucks. To me it's not worth possibly of scratching the fender trying to save them when removing them!  :D
« Reply #3 on: June 10, 2011, 04:18:34 PM »
My front wheel has been on and off many times and I've not found a reason to remove that fender.
Bob
« Reply #4 on: June 10, 2011, 04:19:58 PM »
Mine was off to install a fender extender!
« Reply #5 on: June 10, 2011, 04:30:01 PM »
Ohhhhhh     I'm still trying to get a radiator hole
Offline katata1100
« Reply #6 on: June 10, 2011, 04:47:29 PM »
My fender got a bad gouge in it and I want to remove so that I can do a proper fill/paint job on it.
Excavator
« Reply #7 on: June 10, 2011, 04:55:33 PM »
Take the bolts out so you can move the fender enough to get your fingers in there to squeeze the clips and pull them out, not real easy but not that bad unless your hands are really big.
Offline Makz58
« Reply #8 on: June 10, 2011, 05:09:50 PM »
Put some rags between the fender and the forks on both sides. Remove the reflector bolts on both sides then the fender bolts. Slide the fender up to make more room to get at the clips from behind (carefull to not scratch fender).  The clips sit in sort of a groove slide a 6mm socket up there on the end of your finger put over the clip points wiggle and wahlah out they come total time maybe 10 minutes for thw whole operation.
C-14 2010
Online VirginiaJim
« Reply #9 on: June 10, 2011, 06:23:15 PM »
I take my fender off to take the wheel off.  Personal preference, nothing more.
« Reply #10 on: June 10, 2011, 07:51:18 PM »
More than likely because you are buzzed and really don't give a shite. :P Removing the front fender is totally unnecessary for front wheel removal by the way.........just sayin. ;)
Online VirginiaJim
« Reply #11 on: June 10, 2011, 08:13:44 PM »
A distinct possibility...
Offline metzgerf16
« Reply #12 on: June 11, 2011, 02:56:30 AM »
"You serious, Clark?"
'09 Red Concours- Sargent seat, Area-P exhaust, BMC filter, PC-V, flies out, PR2's, Murph's risers
'06 Ninja zx10r- Dear tiny baby Jesus, it's fast!
Offline CrashKLRtoConnie
« Reply #13 on: June 11, 2011, 12:32:19 PM »
I took the fender off just so I could follow Fred's video on front tire removal.
Found I could use my fingers but damn those clips are pointy and sharp. (Fred used his fingers)
Finally used some Tri Flow spray to help and the clips pushed out much easier. Only the right side one was hard to remove the other 2 are cake.
(took me 15 minutes and some blood to get the right clip off)
If I was rich and planned better would have bought 3 new ones and just cut them off ...  ???
(I was installing the fender extender and cox rad guard at the same time) ...
2008 C14 GTR1400 AKA "Connie"
Online VirginiaJim
« Reply #14 on: June 11, 2011, 02:16:44 PM »
I never put my clips back...
Offline curly
« Reply #15 on: June 12, 2011, 05:10:15 PM »
Excellent advice about the 6mm socket. I did this yesterday to install a fenda extenda and had the fender off in minutes.
Confidence is the feeling you have before you realize the full measure of the situation.
'09 in Black.
Offline lather
    • Louisiana Chapter MSTA
« Reply #16 on: June 12, 2011, 11:02:02 PM »
Wise man. The clips cause serious problems if your fender ever falls off and gets run over by your front wheel.
Online VirginiaJim
« Reply #17 on: June 13, 2011, 05:09:19 AM »
Should we ask how you know this....?    ;)
Offline lather
« Reply #18 on: June 13, 2011, 08:39:00 AM »
No, just use the search function  :rotflmao:
Online VirginiaJim
« Reply #19 on: June 13, 2011, 11:52:05 AM »
Excellent!  :rotflmao:
