So will that stuff help corrosion on the board?
or is that just contact cleaner.
I'll have to get some tomorrow all I have is 50% on hand
I washed it about a month ago and thought all was well
So dielectric silicone compound is a no no ?
I screwed up my truck key door opener type thing (Dodge) while kayaking (salt water ) does the same thing, works for a while then _____
Where do you get 99%
Glad this one is my spare .
Instead of using alcohol I'd recommend using a good contact cleaner. Hands down the best contact cleaner/restorative that I've used is Cramolin. It'll clean the contacts and keep them from oxidizing.
Will that stuff clean the white crud from around the gashole?
Assuming that white crud around your gashole is corrosion, I bet it would. It that white crud is something else you may need a different type of.... er, cleanser.
But on a serious note, that white crud almost certainly is corrosion. I use a light oil to clean it up and leave a touch of oil behind (no pun intended) wherever I find any corrosion. For some strange reason, I have had good results using automatic transmission fluid (ATF)- I have used it in a pinch quite a few times only to find it seems to last. Works great around battery terminals without leaving gobs of grease behind (again, no pun intended).
Thanks Conrad
Radio Shack part # 640-4338 $14.99 two little cans
DeoxIT Mini -Sprays Connector Cleaner & GOLD G-series contact conditioner/protector
www.caig.com
Just what I was looking for
Amen brother
Thank you for that. Now can you make him clap his hands? Ah, the good ole days...
Let me try to find that Joker with the clap.
A shot of penicillin with clear that right up.
How about a shot of bourbon?
