I don't feel it runs like its been flashed.
Need to sell a few unused items so I can send the brain on a Florida vacation at concours boot camp for a proper attitude adjustment.
i glanced at the speedo after letting it breathe in 5th on an open stretch of slab this afternoon. I caught the needle dropping from a couple notches over 160 after I chopped the throttle. It was still pulling strong when I backed off.
After safe arrival at the hideout, I yanked the seat and pulled the ecu out from the strap looking for evidence of tampering (flash sticker).
2012 bought used this April with under 10k miles. I don't feel it runs like its been flashed. Wont come close to power wheelie without clutch in any gear. No sticker, appears bone stock aside from battery tender connector and tires.
I understand indicated speed doesn't mean actual speed, but I was well over 155 (limiter is set at 154 on gen2, no?) as far as the bike was concerned. What gives?
oh, found the rev limiter this morning This thing is FUN. Need to sell a few unused items so I can send the brain on a Florida vacation at concours boot camp for a proper attitude adjustment. Hopefully can sneak that by the financial advisor this winter.
I'm not sure that I understand. Did the previous owner tell you that the bike had been flashed? Is that why you were surprised by the speed limiter at 154 (that would be actual speed, not speedo indicated)?
No such limiter on the superior gen one C14.
C, you ain't alone. I'm not sure I'm understanding the question either. So the OP isn't happy about 165mph indicated? Sounds like to me it's running fine. What's the issue?
To my knowledge, there isn't a "speed" limiter, only a "Rev" limiter within the ECU.
There have been several GPS documented 165 MPH runs (in 5th gear as there's too much wind resistance to go this fast in 6th). The main reason that the C14 "normally" tops out in the 160's is mostly due to the Aerodynamics & Wind Resistance. Oh and the size of the riders balls.......
So Jethrobolas.... How was your bike configured when you made this run? With or Without the hard bags? Do you have the "stock" windscreen or aftermarket? I'd presume that you had the windscreen at it's lowest setting and you were in a "tucked" position, but again, that is just a presumption.
I have no references to quote, but somewhere on the internet was read by my cousin's ex-girlfriend's brother-in-law's acquaintance's friend ( ), and it said that the GEN I C14's were limited to 300 kph (186.411 mph) and that Gen II's were limited to 250 kph (155.3 mph) from the factory.I have read the same thing, and that is the reason I started this thread. Honestly, I thought it was a well known fact.
Somebody check that out for us will you?..... I'm just too busy right now.
I’m happy but confused because the bike is not supposed to go that fast in stock form.
The whole reason I keep typing “indicated” is because that’s what the speedo was reading which, in theory, is what the bikes computer thinks my velocity is. Theres no gps built into the bike that I’m aware of, so when the speedo reads 154 it should go no faster being limited to that speed by the factory programming(regardless of actual speed). Why was it still pulling into the 160s?
As I said, more testing is needed to verify the apparent anomaly. Whenever the opportunity arises again.
No need to think too deeply about it. Obviously this must be the first report of this happening. Maybe I’m just loosing my marbles. I will return to this thread either yay or nay when I try again.
I found this. Not sure why the C-14 is 155, other than the fairing would make it less stable above that speed.
Or the agreement changes from 186 to 155 for certain class of motorcycles.
Best Answer: The OEM Japanese manufacturers decided to limit the speed of any bike that could approach 200 mph to 186 mph.This was done in 2001.Mainly the reason was to keep the goverment from stepping in and setting horsepower limits.In 1980,in the USA,we had senators screaming about "Killer Superbikes" and wanting to set HP limits then. Luckly, it did not happen. This Agreement was widely reported on in 2001 by all the M/C magazines.
A number of my motorcycles over the years have had a speedo error of around 12%, that would make your actual speed about 145, at an indicated 165, well under the limit. My RC51 had an error of 8%, so an indicated 165 would be 151.8, also under the limit. An 8% error is not uncommon.
Yep, perception and the belief [...] we must 'do something' about this horrible problem, whether it is either horrible or even a problem or not. [...] Perception trumps reality every single time
