Vote to be part of the KIPASS BYPASS MOD by BDF
Vote to be part of the buy....
100 (87.7%)
Don't press this button.......
14 (12.3%)
Total Members Voted: 114
Author Topic: KIPASS BYPASS Mod by BDF  (Read 264609 times)
Re: KIPASS BYPASS Mod by BDF
« Reply #20 on: February 17, 2012, 12:44:34 PM »
Which thread is that?
Yes, which thread?
« Reply #21 on: February 17, 2012, 12:46:02 PM »
Almost perfect Conrad. The only thing you missed was the switch- I am using a removable fuse instead of a switch because it is more reliable, and I am looking for the ultimate in reliability here, and it will only be used rarely. Plus a fuse holder is much easier to be absolutely sure it is weatherproof. I can offer the harness with a waterproof switch but I cannot guarantee the switch's reliability and the last thing I wanted to do was to introduce yet another piece of electronics into this chain that is not 100% reliable. After all, it is a switch failure that causes the problem in the first place so I do not believe adding another switch to the circuit is the best way to go (and either switch failing will cause a starting failure as they are in series and of opposite operation).
So here is the deal: the sub harness is exactly like an extension cord, you simply open the factory connector and place the new harness in-line. The sub harness has a pig tail that contains a fuse- should the activation switch fail or stick 'ON' as does occasionally happen, simply remove and reinsert the fuse and KiPass will activate (exactly as it does when you press down on the ignition key).
NOTE: you will still need a functioning fob to start the bike! This harness DOES NOT by pass KiPass, only the KiPass activation switch. This harness cannot be used to replace a lost / broken fob or steal a C-14. This by pass does address the only problem that KiPass has ever had, to the best of my knowledge, 100% of the time though and cannot fail to work around a stuck switch.
This product is made in the USA from the best components available. The connectors themselves are Japanese. Price is not yet determined but I will post it shortly. Price was not the object of this endeavor though, ultimate reliability and quality were.
A few photos:
The sub- harness itself:
The stock connector on a C-14:
The sub- harness installed into the bike's harness:
And, of course, this product is fully endorsed by Kirby. In fact, it is the second generation of Kirby's KiPass Korrection Kit.
Whatcha makin Brian? A harness that plugs in between the two connectors under the left side that incorporates a switch?
« Reply #22 on: February 17, 2012, 12:46:50 PM »
This same thread, just a bit further down than your post.
« Reply #23 on: February 17, 2012, 01:03:45 PM »
Nicely done Brian.    :thumbs:
Offline marku8a
« Reply #24 on: February 17, 2012, 01:36:44 PM »
Please count me in.
Mark
2009 C14 Red
Fly_ectomy, K&N Filter, Oxford Heated Grips, PC V, Full Area P Exhaust
How far can a person run into a forest?
Offline seajay
« Reply #25 on: February 17, 2012, 01:46:32 PM »
Please add me to the list.
09 C14 ABS, Black
Online VirginiaJim
« Reply #26 on: February 17, 2012, 02:01:10 PM »
Seems the demand is quite strong so far...  :thumbs:
Offline CigarSki®
  • Newb again?
« Reply #27 on: February 17, 2012, 02:52:34 PM »
I'm still wiating for the plug&play fully electronic cruise control... ::)
Wayne Sikorski aka CigarSki
2010 ZG1400 - South Jersey
COG 9250
Offline JhVenezuela
  • Country: ve
« Reply #28 on: February 17, 2012, 03:14:46 PM »
count me in.
Offline Bosco
  • USA
« Reply #29 on: February 17, 2012, 03:17:09 PM »
Awesome job.
1999 Concours Sold
2009 Concours ABS
« Reply #30 on: February 17, 2012, 03:19:13 PM »
Endorsed by Kirby? How can one go wrong, add my name to the list, dependant on pricing.
Online VirginiaJim
« Reply #31 on: February 17, 2012, 03:21:20 PM »
Dependent on pricing?  It can't be that much......can it?
« Reply #32 on: February 17, 2012, 03:25:54 PM »
I wouldn't think so but Kirby does need a new pair of shoes, so who knows?    :P
« Reply #33 on: February 17, 2012, 03:29:00 PM »
Is it possible to use the poll feature as a counter we can click so Brian has an accurate count on how many of these he might need ?
Offline Axxman
« Reply #34 on: February 17, 2012, 03:30:40 PM »
I would like one as well ;D
Jay
Jay
09 Concours 14 ABS
Candy Diamond Red
Online VirginiaJim
« Reply #35 on: February 17, 2012, 03:33:34 PM »
It's possible and it's a good idea.  Unfortunately, it wants two buttons instead of just one.  So go to voting but don't press the second button.
« Reply #36 on: February 17, 2012, 03:37:12 PM »
I wonder what happens if I press the button that says don't press this button?    ;D
Online VirginiaJim
« Reply #37 on: February 17, 2012, 03:38:07 PM »
You get thumped.
Offline wally_games
« Reply #38 on: February 17, 2012, 03:38:18 PM »
That, my friends, is a thing of beauty!
I still have a question for everyone that's ever had a KiPass issue. What model year do you have that failed? I wish everyone that posted that theirs stuck would start their post with that tidbit of info.
When did Kawasaki change to a stronger spring? Wondering if my '11 has the beefier one.
« Reply #39 on: February 17, 2012, 03:40:24 PM »
You get thumped.
And billed for all the kits.
