Author Topic: How do you get the lock cylinder out of the side bag key assembly  (Read 1301 times)
Offline ethorpe65
  • Enjoy The Ride
Hello all,
How do i remove the key barrel from the Side bag lock assembly on my 2010 ZG1400 Concours?
Thanks in Advance
Offline MtnRider
Re: How do you get the lock cylinder out of the side bag key assembly
« Reply #1 on: May 06, 2020, 11:45:18 AM »
I made a removal tool from some scrap steel about 1/16" thick. See picture. Looking at the lock cylinder, the largest slide all the way to the left is what latches the cylinder in place. Insert your tool into the key slot and at the bottom push it toward the lower side of the picture. You'll be able to feel the latching pin move to the side and the cylinder should pull out. Looking at the tool, the tab at its left edge could be wider (L/R direction in the pic). Mine is thin enough it can slip under the latching pin so I have to lift it off the bottom of the cylinder and keep it aligned with the pin. Making it wider would reduce the touchy-feely factor and the process a little easier. Hope that helps.
No need for the tool to install. The barrel the lock goes into has a ramp to compress the latch, you just push on the cylinder to install.
Leo
« Reply #2 on: May 06, 2020, 03:54:21 PM »
Since you can't remove the key in the unlocked position, are you saying using that tool, you can remove the cylinder from the bag without a key and in the locked position?
Offline MtnRider
« Reply #3 on: May 06, 2020, 06:01:51 PM »
Yes. It has to be in the locked position since you have to have the key out to use the tool. I've only tried it with the key out & in the locked position, anyway.
Offline MtnRider
« Reply #4 on: May 06, 2020, 06:07:28 PM »
I'm willing to make a better sized one for community use and sharing. Can't say it will be any prettier though.   :rotflmao:
Respond to this thread and send me a PM with your address for the first to respond. Then you're responsible for sending to the next one who needs it. All free of charge. If a couple of people have an immediate need, I can make 2 or 3. I would still like to see them passed around.
PS 1: the bags can be unlocked with the cylinder out with a screwdriver. (Edited)  (Thanks Michelle!)
PS 2: I believe it works on the seat lock cylinder and factory top cases, too, as the cylinder part numbers are the same.
PS 3: To match a cylinder to your current key buy: https://www.revzilla.com/motorcycle/kawasaki-kqr-47-liter-top-case-one-key-system-type-1
Leo
« Last Edit: May 07, 2020, 05:23:18 AM by MtnRider »
Offline Michelle
  • Saving the chubby unicorns
« Reply #5 on: May 06, 2020, 07:49:07 PM »
PS 1: the bags are still locked with the cylinder out so it's no use to a thief.
Not so. With the key barrel removed the lock mechanism is exposed and the bag can be opened with a screwdriver.
Glitter White 2010 1400GTR
Windsor Green 1997 GTR1000
Offline MtnRider
« Reply #6 on: May 06, 2020, 10:48:24 PM »
Oops. I'll fix that. Thanks.
« Reply #7 on: May 07, 2020, 05:46:18 AM »
Wow, so much for security :)
Of course, I never thought of it as all that secure in the first place, but having a design like this seems really bad.  Most locks do not work like that, they require a control key, or removal of a bolt or nut or something from the secured side of the lock.
Offline MtnRider
« Reply #8 on: May 07, 2020, 09:44:12 AM »
Yeah. After posting the info above I've had second thoughts to whether it should be posted in the open, at all. Although, I found this information on YouTube so it is already out there if you look for it. If there's a consensus to pull it, I will.
I also had the "It's not all that hard for a determined thief to get the bags off even if locked" thought.
« Reply #9 on: May 07, 2020, 12:55:09 PM »
Well, what's the consensus?  Shall it go or shall it stay?
« Reply #10 on: May 07, 2020, 04:19:11 PM »
https://youtu.be/BN1WwnEDWAM
« Reply #11 on: May 07, 2020, 04:31:58 PM »
We have a name for this situation in my field:
"Security through obscurity"
https://en.wikipedia.org/wiki/Security_through_obscurity
« Reply #12 on: May 07, 2020, 07:44:15 PM »
That can certainly be said about the systems I work with.
