Author Topic: Part numbers and such for the C14  (Read 52297 times)
Online VirginiaJim
« on: June 12, 2011, 11:37:10 AM »
KAWASAKI PARTS UNLESS NOTED
Places to order Kawasaki OEM parts
http://www.riderschoiceracing.com/Default.asp  (Free shipping for orders over $15)
http://www.ronayers.com
2010 C14 Service manual - 99924-1431-01
AIR FILTERS
Air Filter Element - 11013-0014
BMC Air Filter - 466/04
K&N Air Filter - KA-1406
Fuel
Fuel Pump filter/strainer/whatever 49019-0013. From a 2013 Kawasaki 750 side-by-side (not sure what they are calling it).
Fuel Pump O-ring - 670E5075
Fuel pump (fuel pump housing would need to be disassembled) http://www.fuelpumpfactory.com/Kawasaki-fuel-pump-Concours-14-s/6323.htm
WASHERS & Push Rivets
Final Drive Crush Washer - 92022-1086
Final Drive O-Ring for Filler Cap - 92025-1735
Oil Drain Plug Crush Washer - 92065-097
Water pump coolant drain crush washer - 92200-0498 Adept Power Sports
Fairing screw nylon washers:
5.3mm ID X 11.5mm OD X .5mm thick - 92200-0006
10.4mm ID X 19mm OD X .5mm thick - 92200-0157
Windshield mounting screw nylon washers:
10.3mm ID X 17mm OD X 1.0mm thick - 92200-0380
Nylon Push Rivet (two sizes) - 92039-0051 & 99039-0051
Push rivet under the windscreen - 92039-0048
Motosport.com Bolt Brand 6mm Nylon Push Rivet - 2005-6RIV (These may not work)
Balkamp part number 665-1446 (pkg of 9) available at NAPA for (rivet 92039-0051)
Hillman push-in Nylon Rivet - 1/4 inch H#881216 (Lowes) barcode 0823671607, for the top of dash
Grainger http://www.grainger.com/Grainger/Push-In-Rivet-5MUF8 (not sure if these fit)
Amazon http://www.amazon.com/Tusk-Kawasaki-Suzuki-Fender-Rivets/dp/B0039LEU0I (not sure if these fit)
MC OIL FILTERS Designed for the bike
Kawasaki 16097-0004
K&N KN-303
Mobil1 M1MC-134 (crosses to a K&N KN-303)
Hiflofiltro HF303/303C
Amsoil EaOM103
Emgo 10-82222
Fram PH6017A
Parts Unlimited 010035X
Oil Filters others use (other than OEM fitment - use at own risk)
A/C Delco - PF2135
Amsoil - 24942 (I think this is a Wix filter)
Napa Gold - 1358
Napa - PS1358 (black and costs less)
Purolator ML16817 (made for MC, not sure if it fits our bikes)
Purolator Pure One - PL14610 (Note: The Purolator website does not recommend using cage filters on MCs)
Purolator Pure One - 2.5"- PL14612 (Note: The Purolator website does not recommend using cage filters on MCs)
Wix - short: 51358; long:  51356
Champion 7317 (same as SuperTech)
Mobil 1 M1-110
BULBS
Tail License Plate Bulb - 92069-1055, 5007, R5W (5 watt)
Front/ Rear Turn Signal Bulbs - 92069-1125
Turn signal bulbs are 7507A bulbs (BAU15s base)
Headlight Bulb 12V-60/55W - 92069-1002 (standard H4)
Small headlight Bulb 12V/5W - 92069-1016
City lights are either a 2825 (5w) or a 2886 (6w)
City lights (LED, inverted cone, white) 194 or 168
Switches
SPST Waterproof Miniature Rocker Switch (On-Off) 16A Green 12V (also available in red) .921" Long x .685" Wide x .551" Deep  Part Number: NTE-54-204W $5.40 each https://shop.vetcosurplus.com/
TIRES/Wheels
Front Tire Size - 120/70ZR17
Rear Tire Size - 190/50ZR17
Front bearing seal (08/09) 92049-0050
Rear bearing seal (08/09) 92049-1061
Wheel Bearings (F) - 6005UU  oem, or 6005 2RS1 or 6005 2RSH (SKF replacement numbers)
Wheel Bearings (R) - 6304UUC3 oem, or 6304 2RS1 or 6304 2RSH (SKF replacement) the "C3" designation is a standard for precision, SKF bearings are normally C3 unless specified otherwise...
Rear Wheel Bearing All Balls - 25-1353 (Comes with one seal - you need one kit - it has two bearings)
90 Degree retrofit valve stems for the original tire sensors:  Honda part VALVE ASSY., RIM 42755-MCA-R31 2014 Goldwing
Steering
Steering Stem Bearings - All Balls Racing -Tapered roller bearing and seal kit for steering stem (steering head) C-14
Part No. 22-1039 Cost: $47.95  http://www.allballsracing.com/
BRAKE STUFF
Front pad Assembly - 43082-0071 (2 EA) (08-09)
Front pad Assembly - 43082-0112 (2 EA) (2010)
Rear pad Assembly - 43082-0055 (1 EA)
Rear brake pads - EBC FA254 (Kevlar) or FA254HH (Sintered)
Front brake pads - EBC FA417/4HH (Sintered)
Front pads - Ferodo FDB2220ST (mcstuff.com p/n 454-1071, requires two sets)
Rear pads - Ferodo FDB2111P (p/n 454-2682) (evidence is these don't last as long or bite as well as other brands)
Carbone Lorraine - 1177SBK5 (front x 2), 2813RX rear
Front ABS brake line - Galfer SS FK003D625-3
Caliper rebuild kits - https://brakecrafters.com/product/caliper-seal-kit-bcnr0036/
Gen1 vs Gen 2 ABS parts
08 front:
21176-0075   SENSOR,SPEED,FR
21007-0068   ROTOR,SENSOR,FR
16082-0023   PUMP-ASSY-OIL,WET TYPE
21007-0069   ROTOR,SENSOR,RR
21176-0076   SENSOR,SPEED,RR
2010 front:
21176-0130   SENSOR,SPEED
21007-0140   ROTOR,SENSOR,FR
16082-0041   PUMP-ASSY-OIL,WET TYPE
21007-0141   ROTOR,SENSOR,RR
21176-0131   SENSOR,SPEED,RR
Engine Parts
Spark Plugs - CR9EIA replaced by CR9EIA-9, gap .036  IRIDIUM!
Valve cover gasket - 11061-0263
Pulsing Cover gasket - 92055-0086
Oil pan drain bolt - 92066-0079
Oil pan drain bolt with magnet - MP-01, MP-11 for the rear drive  http://www.magneticdrainplug.com
Manual Cam Chain Tensioner  APE KTZx14
(NOTE:  This replaces the self adjusting cam chain tensioner and eliminates the 'startup rattle'.  Downside is that you will have to keep an ear out on the adjustment.  There is no track record on how long the adjustment holds.  USE THIS AT YOUR OWN RISK! )
Replacement Exhaust Header Nuts - McMaster-Carr 93795A230 M8.0 Oval Locknut.  Use with stainless steel washers.
Fuji-lok nuts for the Exhaust Header - Use with stainless washers
Note:  the '10 manual specs 13ft/lbs for torque.   This should apply to the other manuals as well.
Oil filler cap - 16115-1009 (note:  Fits the rear drive as well)
Tools
Oil filter wrench - 57001-1249
Pennzoil oil filter wrench 2"-3 3/4" 51mm to 95mm
JIS +2 Driver (for the 'flies)  http://www.ikaswebshop.com/hodjis2dr12s.html
15mm drag link tool for rear drive filler plug http://search.harborfreight.com/cpisearch/web/search.do?keyword=drag+link
Stem nut socket from CycleDude
Steering stem top nut - 12mm hex  79.7ft lbs torque
Front wheel removal - 13/16" spark plug socket, reversed
Rear Axle - 27mm socket for the large nut, 14mm hex wrench for the left side
Final Drive
Filler cap o-ring - 92055-049 (31mm)
Swing arm
OEM Left hand side torque arm bolt is 10x63mm with part number 92153B (used to be 92153A)
OEM Right hand side torque arm bolt is 10x67mm with part number 92153C (used to be 92153A)
The flanged lock nut part number is the same for both bolts 10mm diameter nut with part number 92210B
Electrical
Battery for FOBs - CR2025 3v (watch battery)
Battery for TPS -  CR2032L/F1N http://www.digikey.com/product-search/en?x=0&y=0&lang=en&site=us&KeyWords=P668-ND
Other sources for TPS batteries https://octopart.com/cr-2032%2Fvcn-panasonic-19088802
Or P660-ND check both of them out on digikey's site.
12V bike battery sources
Stock battery FTZ14-BS Furakawa - dealer sourced most likely (expensive)
AGM MBTX12U 14AH by MotoBatt (I have this and it's working fine, no issues)
Shorai battery LFX21A6-BS12  Tender SHO-BMS01
Battery Stuff  http://www.batterystuff.com/powersports-batteries/sYTX14-BS.html
Bodywork
Left side cowling parts  39156-031, 033, 034, 0371, 0395
Battery cover stud rubber grommet - Frame fittings, p/n 92075-1011, damper
Levers
Brake - ASV BRC511
Clutch - ASV BRC511
Key Blanks
Key Blank - ILCO KW14R  Warning, this may only work for the 08 model locks and there appears to be two types of keys in use.  The KW14R only works with one of them.  If your key starts with an A it will be a "Silca KW14R" keyblank.  If it starts with a B it will be an "Silca KW14" keyblank.
Works ok on the bags but you will need to not insert it the whole way for the seat as it doesn't have the stop the Kawi key does. http://www.mysecuritypro.com/index.asp?PageAction=VIEWPROD&ProdID=663
Ron Ayers has new Oven Knob keys.  A and B style key. If you look at your key in the fob it will have a number that starts with either A or B.
27008-0050  Style A
27008-0051  Style B
PAINT
2008 Neutron Silver, factory OEM code 17N
Color Rite - (3895), Base (1895) note: requires both base and top pens
2009 Candy Diamond Red, factory OEM code 25T
Color Rite - (3785), Base (1785), Flat Super Black for the engine cover and lower cowl (1785), Metallic Phantom Silver for the trim and wheels (3803)
http://www.colorrite.com/matrix-colors.cfm?CFID=2087880&CFTOKEN=46483776
TPMS sensor part numbers
US bikes 315 Mhz (green).   Note that EUR, AU, SEA use 434Mhz sensors (blue).  MY (have no clue what MY stands for) sensors 315Mhz (red)
2008-2013 21176-0125
2014-2015 21176-0748
Misc. Stuff
Thread locker - VibraTite VC3
http://www.wttool.com/product-exec/product_id/44651/nm/Vibra_Tite_VC3_Anti_Vibration_Thread_Locker
« Last Edit: January 25, 2021, 06:04:15 AM by VirginiaJim »
Re: Part numbers and such for the C14
« Reply #1 on: July 25, 2011, 01:06:00 AM »
Great info, once again it saved me from diggin' info....thanks!
Offline sqwuch
« Reply #2 on: February 14, 2012, 03:59:11 PM »
Hi VAJim
Shorai change Battery models for C14 to LFX21A6-BS12
 Their battery tender SHO-BMS01 can be left on the bike indefinitely keeping the battery at 60 ~ 80% charge levels. (Ideal range for long term lithium-iron storage and it will still easily kick over engine)  It also has diagnostics to balance the cells.
If you order from their site and mention you attended the IMS they will offer 10% off.  www.shoraipower.com
These batteries are maintenance free and more than half the original batteries weight  (about $200) and are supposed to last longer.
(I'm not affiliated with  Shorai in any way)
Online VirginiaJim
« Reply #3 on: February 14, 2012, 05:30:13 PM »
Thanks!
Offline Slvrvalk1
Champion oil filters = Wall Mart Supertech
« Reply #4 on: June 06, 2012, 09:30:20 PM »
I did not do a search to see if this has already been posted, but there was a thread earlier about filters.  I got this information from my Valkyrie web site.  The Wall Mart Supertech filters are made by Champion.  The one that fits the Concours 14 is the Champion 7317.  Here is a link to get them for $2.95.  I do not know what shipping will be from Summit Racing.
http://www.summitracing.com/parts/CPN-CL7317/
Dave
Online VirginiaJim
« Reply #5 on: June 07, 2012, 04:55:25 AM »
Thank you, Dave.
Offline lather
    • Louisiana Chapter MSTA
Re: Champion oil filters = Wall Mart Supertech
« Reply #6 on: June 07, 2012, 06:31:17 AM »
Dave
Thanks, I just ordered 6 and total shipping was 4.95
Offline Diablo6v
« Reply #7 on: September 20, 2015, 05:34:35 PM »
Napa part number for rear wheel bearings 6304.
« Reply #8 on: September 25, 2015, 01:36:56 PM »
the correct replacement wheel bearings are....
front is 6005UU  oem, or 6005 2RS1 or 6005 2RSH (SKF replacement numbers)
rear is 6304UUC3 oem. or 6304 2RS1 or 6304 2RSH (SKF replacement) the "C3" designation is a standard for precision, SKF bearings are normally C3 unless specified otherwise...
both these bearings have buna-n rubber contact seals on both sides.
her ya go....
Online VirginiaJim
« Reply #9 on: September 25, 2015, 02:43:15 PM »
Thanks for the additional detail, Rich and to Diablo6v for spurring on the updating of the bearing numbers.
« Last Edit: September 25, 2015, 08:08:40 PM by VirginiaJim »
« Reply #10 on: August 30, 2018, 03:57:04 PM »
Key Blanks
27008-0050  Style A
27008-0051  Style B
TO UPDATE THIS....
COMPLETE KEY CODES BELOW...
27008   27008-0048   KEY-LOCK,BLANK,#A
27008A   27008-0049   KEY-LOCK,BLANK,#B
27008B   27008-0050   KEY-LOCK,BLANK,#A,MAIN SWITCH
27008C   27008-0051   KEY-LOCK,BLANK,#B,MAIN SWITCH
27008D   27008-0062   KEY-LOCK,BLANK,#A,SPARE FOB
27008E   27008-0063   KEY-LOCK,BLANK,#B,SPARE FOB
AND PICTORIAL
Online VirginiaJim
« Reply #11 on: August 31, 2018, 05:20:00 AM »
Thanks, Rich.
Offline connie_rider
« Reply #12 on: August 31, 2018, 08:38:21 AM »
All good info. Thanks for posting this.
NOTE: I opened the Riders Choice and it sez I need to buy into the Domain.
Is this in error?   http://www.riderschoiceracing.com/Default.asp
« Reply #13 on: August 31, 2018, 09:41:43 AM »
I think they folded. You might be able to buy one of their signs? Nope, too late, auction ended.
http://www.bullockauctioneers.com/auctions/detail/online-only-riderschoiceracing-bw12711
Facebook page says "Permanently Closed"
Offline Eupher
  • U.S. Army, Retired
« Reply #14 on: January 24, 2021, 05:55:52 PM »
May want to add this to the Washers and Push Rivets section:
92200-0498 - Water pump/Coolant drain crush washer. This one was not on Ron Ayers site, but I found it on the Adept Powersports site. I got two for $1.55.
2012 C14 Arabian Candy Red
2003 Honda 919
1981 Suzuki 650E
1965 Honda S90
Online VirginiaJim
« Reply #15 on: January 25, 2021, 06:04:37 AM »
Thanks!
