Author Topic: Ebay Bar Risers  (Read 6944 times)
Offline oldsmoboat
Ebay Bar Risers
« on: June 09, 2011, 07:40:34 PM »
Bought a set off Ebay.  The center insert doesn't even come close to going in.  How much can I spread the bar apart?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=260763950975&viewitem=&sspagename=STRK%3AMEWNX%3AIT
Offline Daytona_Mike
Re: Ebay Bar Risers
« Reply #1 on: June 09, 2011, 08:01:08 PM »
What bar?  Maybe some pics will help
Offline oldsmoboat
Re: Ebay Bar Risers
« Reply #2 on: June 09, 2011, 08:06:40 PM »
2004
Offline throb
Re: Ebay Bar Risers
« Reply #3 on: June 10, 2011, 03:56:46 AM »
You could always remove some of the metal from the inserts.  I have the same ones, but not sure if I bought them from the same seller, but mine dropped right in.  Don't forget a dab of thread lock on those little b*%^@%^ set screws that go in the side of the risers.
Offline Dan
Re: Ebay Bar Risers
« Reply #4 on: June 10, 2011, 04:44:30 AM »
Bummer, I thought of ordering a set of these but not if there NO GOOD...  anyone ELSE have these problems>>??
Offline Dan
Re: Ebay Bar Risers
« Reply #5 on: June 10, 2011, 04:45:56 AM »
Gene, would u just grind em down??
Dan
Offline gtr1000
Re: Ebay Bar Risers
« Reply #6 on: June 10, 2011, 11:53:51 AM »
There's no way should you have to mod the blocks.
If they don't fit, send em back and ask for another set or get a refund.
Paul OTP (near Windsor, GB).
06 C-10, 2009 to .....
A5 C-10, 2000 to 2009.
Offline throb
Re: Ebay Bar Risers
« Reply #7 on: June 10, 2011, 06:15:03 PM »
  Depends how much would have to come off them,  OP says they are not even close.  Close only counts in horse shoes and hand grenades where I come from, so it can mean anywhere from .001 to 3 miles depending who you are talking to.  If he can take a slight amount off and use them, so be it.
Offline oldsmoboat
Re: Ebay Bar Risers
« Reply #8 on: June 10, 2011, 06:21:55 PM »
Ya, I am going to take a belt sander to them.
Offline gtr1000
Re: Ebay Bar Risers
« Reply #9 on: June 11, 2011, 09:07:40 AM »
Why? If they're advertised to fit the C-10 and don't, then they ain't right.
A bit like buying a wrench advertised as 1/2" and being sent a 3/8" one and having to machine it out  :o
Offline connie_rider
Re: Ebay Bar Risers
« Reply #10 on: June 11, 2011, 09:39:40 AM »
I agree. Before you grind, contact the seller......
Something doesn't sound right.
Dumb question, but did you loosen the pinch bolt??
« Last Edit: June 12, 2011, 08:36:41 AM by connie_rider »
Offline oldsmoboat
Re: Ebay Bar Risers
« Reply #11 on: June 11, 2011, 03:13:01 PM »
I loosened the pinch bold and drove a screwdriver tip into the opening to spread it out more.
I was whacking it pretty good and got worried about breaking the handlebar.
The reason I am not sending it back is because it's not worth the hassle.
Offline booger
Re: Ebay Bar Risers
« Reply #12 on: June 12, 2011, 07:23:19 AM »
3 miles would probably be a little too much ;D
Re: Ebay Bar Risers
« Reply #13 on: June 12, 2011, 08:41:34 AM »
On a past purchase I made from Ebay I sent a seller a note with an explanation of a problem.
The seller replaced the bad part and told me he apologized for the problem. Told me not to send the old one back. Was decent about it.
Go ahead and grind, but try sending a note. Couldn't hurt.
Offline Dan
Re: Ebay Bar Risers
« Reply #14 on: June 14, 2011, 04:06:34 PM »
agreed, which seller, as I do want to get a set....
maybe not from them, send em a note, see what they say, if they back it. ok..
Dan
Offline Dan
Re: Ebay Bar Risers DID THEY WORK..?
« Reply #15 on: June 17, 2011, 09:40:14 AM »
I WANT TO GET A SET,
oops.
And I want to order today.....  hose are half the price of most, anyone else have any trouble with these??
Anyone have success?
Thanks
Dan
Offline oldsmoboat
Re: Ebay Bar Risers
« Reply #16 on: June 17, 2011, 12:05:39 PM »
Dan
I'll post a link tonight.  I can't access Ebay at work.
I did contact the seller as many suggested.  He sent out another set that has been partially machined down.  I'll try them out tomorrow.
Offline Uded2me
This forum is dead dead dead
« Reply #17 on: June 17, 2011, 12:24:53 PM »
d e a d
« Last Edit: February 21, 2016, 09:06:20 PM by knight_mare »
Offline deadzed
Re: Ebay Bar Risers
« Reply #18 on: June 17, 2011, 02:50:36 PM »
I have the same set on my '05. No problems. (after re-routing the choke cable.)
“And I to my motorcycle. Parked like the soul of the junkyard restored, a bicycle fleshed with power, and tore off up Highway 106, continually drunk on the wind in my mouth. Wringing the handlebar for speed. Wild to be wreckage forever”
James Dickey
Offline oldsmoboat
Re: Ebay Bar Risers
« Reply #19 on: June 17, 2011, 04:19:45 PM »
Dan
For 94-06
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=260763950975&ssPageName=ADME:X:RTQ:MOTORS:1123
