Author Topic: Coolant bottle relocation  (Read 4550 times)
Offline VodkaAndPickles
« on: April 21, 2012, 02:33:02 PM »
Maybe I'm incompetent, but I can't find any write-up here on how to relocate the coolant reservoir.  Help me out please?  Thanks
Re: Coolant bottle relocation
« Reply #1 on: April 21, 2012, 02:43:20 PM »
the only write up was one I did way back in an issue of the Concourier, but you can get it all here, just read the captions on the pictures....
http://rides.webshots.com/album/197545285ZPOTXA?start=24
heheheeh
I ought to patent the mod, I just realized I posted this back in 2005.... ;D
« Reply #2 on: April 21, 2012, 03:10:12 PM »
heheheeh
Thanks.  You used the stock hoses?
Offline Lodogg2221
« Reply #3 on: April 21, 2012, 09:45:13 PM »
Does it actually help with the heat?  Or is it for running without the lowers on?
Say what?
« Reply #4 on: April 21, 2012, 11:13:53 PM »
Yeah I want to take the lower fairings off for the summer.
Offline elvin315
  • Global Moderator
« Reply #5 on: April 22, 2012, 10:17:10 AM »
heheheeh
Did you read the FAQ?
http://www.zggtr.org/index.php?topic=964.0
« Reply #6 on: April 22, 2012, 11:08:57 AM »
I'm so terribly sorry, evidently I forgot about it....but seeing as I did post in it, it seems as if I did read it....once. ;)
Thanks for sharing the reminder.... ;)
You been ok? haven't see you here much this year?
V&P, the answer is Yes, I used the existing hoses, and rubber bumpers from the original mounting bracket, and original tank.
Only expense was the piece of Velcro, which I already had. Just re-route the hoses, they are perfect length to suffice.
Don't be tempted to overfill the tank, if you install it and the radiator is correctly filled, you only need about 1-1/2" of coolant in the tank when it sits vertical.
« Reply #7 on: April 22, 2012, 11:54:15 AM »
MOB, will the tool tray fit with the stock coolant bottle installed?  Doesn't look like there's much room in Elvin's set-up as it is, and he's using a thinner bottle.
« Reply #8 on: April 22, 2012, 01:51:23 PM »
That wasn't Elvin's article, it was done by Jeff Hunter last year. Elvin is the master Librarian of everything we write.... :D
Jeff's setup, using a different bottle, still allowed the tool tray install, but my (COG-Fugalicios) workup doesn't.
No, you kinda loose the tray for the tradeoff. I originated this when I built my '88 COGZilla, and it was a Nekid bike, needing a relo for asthetics.
I ditched the tool tray on that bike, and ran an el-cheapo thinner battery also, but still could carry tools in a roll-up tool pouch on top of the battery.
I aquired multple Roadgear tool bags as prizes over the years at various rallies/rides.
this works and fits well, and shoulsd help:
http://roadgear.com/sport-touring-tool-pouch-p-46.html
I never used the tool tray for anything other than a place to house my aux fuseblock on my 86, as I had 2 bags and a trunk to haul the "garage tools" in.... ;)
Offline Gottaride
« Reply #9 on: April 23, 2012, 12:51:59 PM »
I mounted my aux fuse block to the fender in the location where you guys have relocated your rad overflow bottles. I recall seeing posted photos a while back showing the overflow bottle located to the left knee area behind or below the tank fairing. A 1 litre oil bottle was used I believe.  Anyone able to come up with details on that mod?
1994 C-10 California model
« Reply #10 on: April 23, 2012, 08:21:11 PM »
This is what I found:
http://www.pbase.com/elvin315/image/48899146
Offline Gottaride
« Reply #11 on: April 23, 2012, 09:25:06 PM »
Nice. Thanks V&P . Just need to flesh out mounting and hose specifics now. Outta be able to cob something together.
