Author Topic: Odometer stopped working  (Read 3463 times)
Offline pat8228
« on: August 16, 2012, 11:14:43 PM »
Last night when I pulled into my driveway my speed odometer was working. Got on bike today and it is not working. Also the minute timer on the tach stopped working. I'm thinking cable broke. Is there anything else that could cause this? Odometer stays on 0.
Thanks for any help.
Offline snarf
Re: Odometer stopped working
« Reply #1 on: August 17, 2012, 05:03:47 AM »
Yup, check your speedo cable.
2002 Conc
1986 Conc "The spirit of COG"
Offline tweeter55
  • Ride Hard...Ride Safe
« Reply #2 on: August 17, 2012, 05:30:35 AM »
Mine broke internally right where it attaches to the front hub.
Boy, is it ever hard to tighten it up well at the speedometer end, at leasat for me it was.
Offline snarf
« Reply #3 on: August 17, 2012, 06:01:28 AM »
I found a cheap basin wrench a few years back it works pert darn good for tightening the top nut. Just pivot the head 90* and get'r done
2002 Conc
Offline tweeter55
« Reply #4 on: August 17, 2012, 06:05:39 AM »
Thanks, Snarf. Didn't give that a thought. :nuts:
Offline pat8228
« Reply #5 on: August 17, 2012, 11:17:48 AM »
 I took the cable off at the wheel and the cable is broke about 2 inches from the wheel. Thanks for your help.
I couldnt get to the end at the gauge, hand just wouldnt fit. That's a great idea about the basin wrench. i have one somewhere just have to find it. Have not seen it in years...
Offline snarf
« Reply #6 on: August 17, 2012, 11:56:09 AM »
Thats easy...Just pretend that you DONT need it and look around for something else.  That is  the only sure-fire way to find a tool.  Cause if you need it you are not going to find it.
2002 Conc
Offline tweeter55
« Reply #7 on: August 17, 2012, 01:48:01 PM »
Take a look at how it's routed. If I remember right, I didn't run mine back through the loop that's attached to the LH side of the fender. I think I ran it straighter out from the wheel. Seems to me it looked like it would bind a little where it broke.
Offline Outback_Jon
« Reply #8 on: August 17, 2012, 03:25:42 PM »
I always seem to find my tools within a week of purchasing the replacement tool.  I'll have to try your method as it appears to be cheaper more frugal.
Offline snarf
« Reply #9 on: August 17, 2012, 03:40:28 PM »
+1 on checking how the cable is routed. I have busted a cable on my 02 and 86. I removed them from the loop and knock on wood; havent busted one since. I also 'cheated' on my first cable. It broke down by the speedo drive. I just pulled it out of the sheath and slipped the new cable back in.
2002 Conc
Offline Uded2me
This forum is dead dead dead
« Reply #10 on: August 17, 2012, 04:37:29 PM »
d e a d
« Last Edit: February 21, 2016, 09:59:35 PM by knight_mare »
« Reply #11 on: August 17, 2012, 04:59:35 PM »
Yep even on my Carbon Fiber fender I drilled it for the black plastic follower as I did not want to risk having the cable mar up a high $$$ fender.... Yes my speedo cable is made of braided SS like the brake lines.
I love my bike........
Offline snarf
« Reply #12 on: August 17, 2012, 07:19:30 PM »
I was talking about the steel loop on the forks under the headlight. Oops.
2002 Conc
« Reply #13 on: August 17, 2012, 07:34:29 PM »
I don't think I use that one for the speedo either just the brake lines....
