Author Topic: Trailering a Concours 14  (Read 1287 times)
Offline thundermax
« on: January 01, 2013, 05:09:31 PM »
Read do not tight strap handlebars down but instead through triple tree. Can someone write about how to secure front end through triple tree without hurting plastic?
Riding 46 years. In order, 1958 Cushman 721 Highlander, 1960 Cushman Super Eagle, 1971 Honda SL 100, 1974 Yamaha RD 350, 1975 Honda 750 Four, 1971 Honda SL 175, 1998 Yamaha Vmax, 2005 Yamaha Vmax, 2009 Kawasaki Concours 1400, 2012 Kawasaki Concours Arabian Red.
Offline thundermax
Re: Trailering a Concours 14
« Reply #1 on: January 01, 2013, 05:14:45 PM »
Accidentally posted here in the wrong place.
« Reply #2 on: January 01, 2013, 05:15:47 PM »
If you keep the angle less than 45 degrees then the straps should be clear of the plastic.   You are only using the lower tree.  I would suggest using a Baxley chock and securing it to your base if possible.
« Reply #3 on: January 02, 2013, 04:00:47 AM »
