Author Topic: Extra brake light installed  (Read 2074 times)
Offline jqram35
  • 2012 C-14 Candy Arabian Red
« on: March 17, 2012, 03:57:40 PM »
Jeff
Re: Extra brake light installed
« Reply #1 on: March 17, 2012, 04:32:13 PM »
Well hmmmm, I guess that will get attention alright, however it appears to be signaling a left turn?
Perhaps that's some strange camera shutter-Brake light LED interaction?..or does it look like that to the eye
as well?
Offline jqram35
« Reply #2 on: March 17, 2012, 04:34:50 PM »
Yeah that is just the video....It is in strobe all at once mode. Don't know why the video shows up like that. I am going to play with the flash pattern. It has 33 different ones to choose from.
Jeff
« Reply #3 on: March 17, 2012, 04:39:53 PM »
I like it JQ, where did you buy it from? Link??
Offline jqram35
« Reply #4 on: March 17, 2012, 04:43:42 PM »
Jeff
« Reply #5 on: March 17, 2012, 05:02:58 PM »
Interested in how you mounted/wired it.  Thanks
Offline coastalconnie
Offline jqram35
« Reply #7 on: March 17, 2012, 05:09:48 PM »
Drilled and tapped two holes on the rack, wired run through existing tail lamp wire hole. Wired up a relay for the strobe since I had to put one in for the Cruise control install coming soon!
Jeff
Offline jqram35
« Reply #8 on: March 17, 2012, 05:11:56 PM »
I liked the bracket on this strobe light better thatn any other one I found plus it is smaller than most. Other thread has a good pic of the wire entry into the body.
Jeff
« Reply #9 on: March 18, 2012, 03:14:17 PM »
Thanks guys, clean installs.
