Anybody? Any suggestions? I just can't figure this out. They work fine hooked directly to the battery or to the always-hot accessory leads under the seat. They just wont work through my accessory fuse block. I have 12V at the switch positive terminal until I switch to hi or low and then the voltage drops to just over 1V and that's it. This usually causes my other stuff on my fuse block to cut out also but this last time I just had all other fuses pulled with just the heated grips working off the fuse block. I gave up and just connected the heated grips to the always-hot leads for now but I don't want to leave them there.
