hit a hard bump in the road, it's only the headlight. I've checked all the wires and the to the ballast (HID) set up and everything looks fine. I was wondering if the relay in the J box could be breaking down? is that possible, or the solder? I am unable to simulate the "blink" when I tap on the J box tho... any ideas? Everything elso works fine. Ive change out the bulb too and the same issue is there.
PS- 06 Connie, 49,xxx miles
Cheers
Ron
