Author Topic: Not enough power ? Try this  (Read 5082 times)
« on: November 04, 2011, 06:55:05 AM »
http://www.muzzys.com/ZX14/ZX14_engines/
       Muzzys performance products now has available new, "in the box" ZX-14 engine assemblies. These 1352 cc engines are complete with 44mm throttle bodies, engine wiring harness, and coils, just as you would install into the chassis. The ZX-14 engine has a bore / stroke of 84 x 61mm and produces approximately 184 rear wheel hp (motorcycle) with tuned racing exhaust. As with all modern motorcycle engines this is a modular unit which incorporates a 6 speed transmission and wet clutch. They have been bench tested before shipping from the factory and are ready to run or to serve as the basis for a race engine build. These engines are intended for off road, racing use only. Engines sold with NO WARRANTY.
Price is $6,295.95 plus shipping
Call Muzzys at 541-385-0706 /
Offline jonathan
Re: Not enough power ? Try this
« Reply #1 on: November 04, 2011, 07:48:28 AM »
They may bolt straight in to the frame but will they just plug in to the ECU?
« Reply #2 on: November 04, 2011, 08:09:44 AM »
If one drops 7K on an engine, a few hundred for an ebay ECO shouldn't factor?
My prob would be my old Zx14 got 29 MPG rendering it useless junk for sport touring purposes.  I wish my C14 would go further between stops and I sometimes carry an extra gallon in case I run out in the middle of nowhere.
Offline Gearhead82
« Reply #3 on: November 04, 2011, 08:32:39 AM »
I'm pretty sure that by the time we do all the basic performance mods to our C14 engine (Full exhaust, ECU reflash to raise rev-limiter, ZX-14 TB's, etc) about the only things we are missing from the ZX-14 engine are higher compression pistons and a little different cam profile.
Offline TRBN
« Reply #4 on: November 04, 2011, 08:49:55 AM »
And how would this "plug-in" to the power train?  Doesn't the transmission and drive assemblies come with the engine?  How would this fit into the shaft drive rear end?  I am probably a bit uninformed about how the power train is put together on these bikes though....
Aaron
« Reply #5 on: November 04, 2011, 10:25:16 AM »
Hmmm, interesting indeed, thanks for posting GP!
I think for close to $7k though I'd just by an entire used ZX14 to play around on and keep the Connie...  :-\
« Reply #6 on: November 04, 2011, 10:53:53 AM »
Offline EpicBadass
« Reply #7 on: November 04, 2011, 01:09:25 PM »
+2
Offline jjsC6
« Reply #8 on: November 04, 2011, 02:29:02 PM »
My thoughts exactly, and I am seriously thinking of doing just that in the not too distant future.
Jim
2010 Concours - Sold Feb 2013
Current bikes....
Offline gonzosc1
« Reply #9 on: November 04, 2011, 02:56:21 PM »
thats the old zx14 engine 1352cc. new ones are 1450cc or 60 something...
« Reply #10 on: November 04, 2011, 03:12:08 PM »
The new zx-14 is 1440 cc.
Offline Scaffolder
« Reply #11 on: November 04, 2011, 03:12:44 PM »
+3
Joel from Maine.
« Reply #12 on: November 04, 2011, 03:16:26 PM »
That might be the reason Muzzys was able to get them. i wonder what the markup is?
« Reply #13 on: November 06, 2011, 07:26:51 PM »
WOW, 7K for an engine, WTF?! Yeah, I would rather just buy a ZX14 and keep my Connie for that price. Then again, if I wanted something faster, I would probably pick up a S1000RR over the ZX14.
