Author Topic: Vista Cruise  (Read 3824 times)
Offline F-106
Vista Cruise
« on: September 04, 2011, 04:21:49 PM »
Finally got my Vista Cruise installed. It works just as good as my $180.00 Breakaway did on my Valkyrie. Hardest part was building a stop to keep the lock assy from moving. Took the bike out and she hold steady at all speeds. Well worth the 20 bucks.
IN THRUST WE TRUST
Re: Vista Cruise
« Reply #1 on: September 04, 2011, 06:45:10 PM »
Looks good!
I also use the Vista Cruise.
Only problem I've ever had is: after a period of time the stop (that locks it place) will wear...
I installed mine so that the thumb bar is located at the top. Most mount theirs like you did...
Either location works fine.
Offline George R. Young
  • Moderator
    • Concours 2001 Farkles
Re: Vista Cruise
« Reply #2 on: September 04, 2011, 07:38:31 PM »
Nicely done. Mine is quite similar:
http://web.ncf.ca/ag136/vistacruise.htm
Offline F-106
Re: Vista Cruise
« Reply #3 on: September 04, 2011, 09:53:49 PM »
I guess you are the man I need to thank for the idea.  It was your link that guided me in that direction for the install. Thanks for posting that by the way :goodpost:
IN THRUST WE TRUST
Offline sas mayhem
Re: Vista Cruise
« Reply #4 on: September 06, 2011, 11:09:56 AM »
F-106, which Vista Cruise did you get, I see that there are a few to pick from...
Cheers
Ron
09 Connie
Offline F-106
Re: Vista Cruise
« Reply #5 on: September 06, 2011, 12:20:45 PM »
VISTA CRUISE  (#20017) This one fits yamaha single/dual throttle cable,  got mine at cycle gear.
Cheers
Ron
IN THRUST WE TRUST
Offline sas mayhem
Re: Vista Cruise
« Reply #6 on: September 06, 2011, 12:32:41 PM »
Thanks
Cheers
Ron
09 Connie
Offline timsatx
Re: Vista Cruise
« Reply #7 on: September 08, 2011, 04:11:06 PM »
This is the way I did mine:
Offline F-106
Re: Vista Cruise
« Reply #8 on: September 08, 2011, 10:22:50 PM »
I like the way you did that install. The problem was my grips would not allow me to install mine that way.
IN THRUST WE TRUST
Offline COG-528
  • Tilting Horizons since 1982
Re: Vista Cruise
« Reply #9 on: October 13, 2011, 07:30:45 AM »
I've been using the Yamaha version of the Vista Cruise on C-10s since 1990.  Prior to that I was using them on the UJMs that they were originally designed for.  My first C-10 install I did the screw into the bottom of the switch housing to keep the Vista Cruise from rotating.  But I found I constantly had to keep re-tightening the screw.  I hand sanded the plastic throttle grip to provide a smooth surface for the Vista Cruise to grip.
On all subsequent C-10s I've used RTV Silcone adhesive to bond the Vista Cruise to the side of the switch housing.  The only drawback to this method is you have to wait 12 hours for the RTV Silicone to cure so you can ride your motor.  I had the plastic throttle grip on my second C-10 turned at a machine shop to provide a more uniform smooth surface for the Vista Cruise to grip than I achieved by handing sanding the first time.  I've moved that throttle grip with the Vista Cruise to my subsequent C-10.
One of the nicest things about the Vista Cruise is it looks like an OEM part of the C-10 when installed correctly.  I used to go to rallies with my first C-10 and have other members asking how come their C-10 did not come with a throttle lock.
Mike Aldea, COG-528   Hawthorne, NJ
Touring broadens horizons . . . Sports Touring tilts them!
Re: Vista Cruise
« Reply #10 on: October 13, 2011, 08:44:37 AM »
Repeat after me... "Next time I will us Double sided tape"..   :-[
