« on: October 09, 2011, 03:50:08 PM »
Hey guys.....I'm partway through the install of an Audiovox cruise control system that I just bought from one of the guys here and had a few questions. I've got most of the wiring done at this point and vacuum canister and lines connected....still need to improve some connections and clean some stuff up and I'm going to tackle the connection to the throttle cable tomorrow I think.
First question......I've got the system connected directly to the battery right now. The control pad powers up and down. I don't have an auxiliary power block so where do you guys normally connect for power so that the system only comes on when the ignition is on?
Second question....I don't think the system is working as far as pulling and holding a vacuum at this point. I've got block off plates so I am pulling vacuum directly off of carb #4 and carb #2 supplies vacuum to the petcock with the other two carbs capped as far as the vacuum ports. I started up the bike and turned on the cruise. I expected it to be working to the degree that I could hold the end of the throttle linkage cable and set the cruise and maybe feel it holding it. I was pretty much just sitting with the bike at idle while checking this so I wasn't riding. I read that these systems should be used at over 35mph so maybe I'm just not pulling enough vacuum for it to do anything.
Third question....should the LED on the servo be on if the system is turned on? I didn't see my LED on when the bike was running and the cruise was on.
Fourth question.....I've got the blue wire that is supposed to go to the ignition coil connected to the black wire that goes to my stick coils. That's what I figured it should go to from the installation instructions that I have. Does that sound right?
I guess that was a little more than a couple questions. I couldn't really find any trouble shooting info on here by searching. I haven't pulled out the volt-meter yet since I haven't got the complete install done yet. I just wanted to see if there were any helpful hints out there. I don't have any LED brakelights or anything like that that should mess up the system as far as the basic install.
Thanks,
Marlan
« Last Edit: October 10, 2011, 06:07:55 AM by mlf73 »
Logged
