Author Topic: transmission issue  (Read 2709 times)
Offline GPz1100
  • Red is Faster
transmission issue
« on: July 11, 2011, 07:40:13 PM »
any had shifting problems? my shifter is hanging "up" after going in 2nd. changed oil about 1000 miles before this started. same oil as always, amsoil 10-40 for bikes...no problems prior to this. also in 1st and 2nd i'm getting a rough vibration that wasn't there before.
imminent transmission failure?
Offline C1xRider
Re: transmission issue
« Reply #1 on: July 11, 2011, 08:37:07 PM »
When in doubt, put in genuine Kawasaki oil and re-test.  If it's still there, you have your answer.
Hmm, another oil thread, with classic Amsoil bashing about to begin...
   :popcorn:
Offline GPz1100
  • Red is Faster
« Reply #2 on: July 11, 2011, 11:19:33 PM »
no, we ain't going there.
Offline Tactical_Mik
  • Lamh laidir an Uachtar
« Reply #3 on: July 12, 2011, 05:42:53 AM »
Just throwing this out there, but some have suggested that a re-torque of engine mounts would settle some vibs.  Might help some.  As soon as it's not 110 degrees I am going to give it a try.
T.S.R.
Offline Rudy
« Reply #4 on: July 12, 2011, 07:11:06 AM »
Amzoil reduced the amount of zinc additive in their oil. Try adding a zinc additive to the oil. There are several brands available on ebay. It worked for me.
Offline jonathan
« Reply #5 on: July 12, 2011, 08:04:14 AM »
What do you mean by "hanging up"? That you have difficulty shifting out of second gear?
Offline GPz1100
  • Red is Faster
« Reply #6 on: July 12, 2011, 09:33:10 AM »
i have to 'tap' down on the shifter so i can shift into 3rd
Offline IRULE
  • How sweet it is...
« Reply #7 on: July 12, 2011, 09:40:39 AM »
Could it be your clutch that is hanging up instead of your transmission?  Could it be that your clutch is not fully disengage?
2009 Red Buell 1125CR
1978 Triumph Bonneville
