Author Topic: removing only one cam- bolt sequence  (Read 1782 times)
« on: July 11, 2011, 02:22:26 PM »
If you are removing only the exhaust cam to change shims should all cam cap bolts be loosened in the prescribed sequence or can the sequence be changed to include only the exhaust cam caps?
Offline JamminJere
Re: removing only one cam- bolt sequence
« Reply #1 on: July 11, 2011, 02:31:14 PM »
Are you sure there is enough play in the cam chain to remove the tensioner, guides, and then to be able to sneak out one cam without removing the other???
I've never seen this done before..
JJ
« Reply #2 on: July 11, 2011, 02:36:28 PM »
Just remove the cap bolts on the cam you want to remove. Leave the other cam caps alone.
You have nothing to lose trying to remove the exhaust cam only because if it does not work you will simply have to remove the intake cam as well. I do think I always had to remove the intake cam first though to get enough slack in the chain to remove the exhaust cam. I may just be associating that sequence though and it is not really nessasary. In the end, don't remove any more cams than you have to as it will just make the job take longer with absolutely no gain at all.
« Reply #3 on: July 12, 2011, 08:54:00 AM »
I just now removed the EX cam without any difficulty. Left the Intake cap bolts alone. Intitially the cam chain did not want to give any slack after removing the tensioner. I had to poke chain guide with a finger to get it loose. Going to swap shims now.
