I assume the part I see on the mid pipe is a heat shield right?
I see. So the mid pipe visible on my 08 is the actual pipe? Wow, very fat! I assumed the visible portion was an outer sleeve.
Thanks for the info. I assume there are more stock pipes out there than need for them so no loss to humanity if I mangle mine up right?
