Like every time I drop a bike off with Steve, I pick it up so much better. This time it was the C14 for a valve job, and tire change, and figure out what Kawi did during a slave cylinder warranty job that trashed my shifting, change plugs, change fluids, bleed the brakes several more things I'll remember after I post.
So many valves needed adjusting, or valves so far out, or a combo of the two where going on, because now the throttle is noticeably more responsive. Shifted rough after warranty work at Kawi, thats fixed. Called me about a bad radiator overflow hose, I said sure change it, and the he didn't charge me any more than we had discussed when I dropped it off.
My tires were the first to be done on his crazy nice brand new tire machine and balancer. I tested the tires to
OHH SHYTE "within posted limits" on i-75, they passed the no vibration test.
Every time I go there someone is either riding a LONG distance or trailered a bike in from somewhere. if I saw this phenomenon with any other mechanic I wouldn't understand. With Steve I totally get it.
Man wow I couldn't thank him enough, and I certainly left a tip.
