Author Topic: Pulsing Coil  (Read 5159 times)
Offline Matt L
Pulsing Coil
« on: August 29, 2014, 07:29:04 PM »
Can anyone help me locate the pulsing coil? Thx!
Offline Rick Hall
  • Eruption
Re: Pulsing Coil
« Reply #1 on: August 29, 2014, 09:27:44 PM »
There's two of them, both under the left side engine cover. Said cover has a rather large screw cap/cover on it. Large enough for a quarter anyway.
The coils are inside.
Rick
Offline DC Concours
  • 2001 Concours, ~35K miles
Re: Pulsing Coil
« Reply #2 on: August 29, 2014, 09:30:32 PM »
what is a pulsing coil and what does it do?
Offline Rick Hall
  • Eruption
Re: Pulsing Coil
« Reply #3 on: August 29, 2014, 09:47:28 PM »
"Pulsing Coil" is Kawasaki's version of a Hall Sensor.
It generates a small electrical current whenever something metallic passes by it. Used to generate a pulse to measure RPM, how many widgets pass by on a conveyor belt, etc. Or in our case, to generate a pulse (that gets amplified in the IC box and coils) that makes spark at the plugs.
Rick
Offline DC Concours
Re: Pulsing Coil
« Reply #4 on: August 29, 2014, 09:57:24 PM »
Thank you. Learned something new today.
Rick
Offline Matt L
Re: Pulsing Coil
« Reply #5 on: August 30, 2014, 07:11:50 PM »
Thanks!
One last question...do I have to drain the oil to remove the coils?
Matt
Offline JDM
Re: Pulsing Coil
« Reply #6 on: August 30, 2014, 07:12:52 PM »
No you don't.
Offline Matt L
Gap Pulsing Coil???
« Reply #7 on: August 31, 2014, 06:22:31 AM »
Do the coils need to be gapped, and if so, what gap?
Offline Rick Hall
  • Eruption
Re: Gap Pulsing Coil???
« Reply #8 on: August 31, 2014, 07:45:46 AM »
Yes. .020-.035" (.5-.9mm).
If curious, both leads of the coil are isolated from ground, and coil resistance should be on the order of 400-600 ohms. There is a disconnect up by the alternator you can use to check this.
Rick
Offline Matt L
Re: Pulsing Coil
« Reply #9 on: August 31, 2014, 08:05:33 AM »
Thanks Rick!
One of my coils was shorting out after the engine got warm.  The other was reading 500 ohms.
Ordered a new set last night.
Thanks again.
Offline Summit670
Re: Pulsing Coil
« Reply #10 on: August 31, 2014, 06:28:28 PM »
Very easy installation and to gap.  I've done mine.
Arctic Cat M8 163 rules
Offline Matt L
Re: Pulsing Coil
« Reply #11 on: September 10, 2014, 08:31:59 PM »
I completed the installation of the pulsing coil.  It was very simple to install.  The gap of the old coil (bike has 36K miles) was about .028", but the new coil was about .022".  I couldn't gap the new coil any differently.  I suppose the gap increases as the points on the coil wear down.
Offline Rick Hall
  • Eruption
Re: Pulsing Coil
« Reply #12 on: September 10, 2014, 09:13:19 PM »
There are no points to wear out :)
The gap is kinda set from the factory. Important things is it's where you need to be, and it runs. I'll assume it runs? :)
RIck
Offline Summit670
Re: Pulsing Coil
« Reply #13 on: September 11, 2014, 07:15:18 AM »
I was able to adjust the gap.  Just loosen the mounting bolts and put a feeler guage in there to set the gap.  With the feeler guage in place, snug the two bolts.  Do for other side and you're done.
Offline Matt L
Re: Pulsing Coil
« Reply #14 on: September 11, 2014, 01:49:01 PM »
RIck
Thanks Rick.  Yes, it runs like a champ.  The points I was referring to are the two metal pieces protruding from the coils (small round metal object protruding from the rectangular coil).  This is the "point" that passes the electric current...if that makes any sense.
