Kawasaki Concours Forum
Welcome,
Guest
. Please
login
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Calendar
Login
The C10, aka Kawasaki Concours - The Original
Accessories and Modifications - C10
(Moderator:
George R. Young
lower heat shields?
« previous
next »
Print
Go Down
Author
Topic: lower heat shields? (Read 2831 times)
Dan
Full Member
lower heat shields?
on:
June 08, 2011, 07:36:39 PM »
Does anyone make lower heat shields for the c 10? I have brians upper heat shields, but my lower leg still gets hot.
ps x country pa to cali trip comin up if anyone wants to ride along....
And if anyone is in central pa I know a great ride up to shamokin from here..
ltr\\
dan
Logged
YoDoc
Guest
Re: lower heat shields?
Reply #1 on:
June 08, 2011, 07:38:33 PM »
I don't know about lowers, but in this Texas heat, I'm pretty sure I'm going to end up relocating the coolant bottle before too long...
Logged
ATC Buckeye
Full Member
Reply #2 on:
June 08, 2011, 09:05:14 PM »
My lower legs are getting cooked as well now that the weather is warm.
Logged
2fast
Full Member
Country:
COG #6497, North Central Area Director
Reply #3 on:
June 08, 2011, 09:51:22 PM »
I'm not sure that blocking off everything would be a good idea. The heat has to get out somewhere, and I prefer it lower vs upper area. If my shins get too warm, I just put my feet on the outer part of the pegs where the air flow is very strong. Flipping your lower scoops to shoot air inward will help a bit too.
Logged
Brian in Minnesota
Need Heat Shields for the C-10? 86-93 Front Brake upgrade brackets? I got em! Click the little green globe under my Avatar on the left.
medicevans
Full Member
Reply #4 on:
June 09, 2011, 08:05:47 AM »
Are you coming through central IL?
Logged
yoman
Full Member
Country:
Reply #5 on:
June 09, 2011, 08:14:30 AM »
Check this out, it was forwarded to me when I ask about heat shields.
http://zggtr.org/index.php?topic=665.0
Ride safe, stay cool
Tom
Logged
2002 Semi-naked Connie
SamSam
Newbie
Country:
Reply #6 on:
June 09, 2011, 11:14:48 AM »
I also would be careful about blocking the lowers as it may cause other heat related problems like melting plastic. I had the heat shields on mine until a plastic gas filter I was using melted. Luckily I noticed it before it completly failed.
Logged
Sal Sammartino
2006 connie, 2001 connie (lost in fire)
COG #6191; If you didn't have a good time it was your own fault!
Dan
Full Member
Reply #7 on:
June 09, 2011, 01:30:02 PM »
not sure about the totall route yet, just have a general idea of 4 or 5 stops we would like to make, the rest will be point and go.. should be great, can not wait, connie under me, and a v strom beside....
ok ttyl.
dan
Logged
Print
Go Up
« previous
next »
(Moderator:
George R. Young
lower heat shields?
