I would reconsider this though, at least if you want a bike you can count on.
And I do, I cannot stand unreliability or unpleasant surprises.
Picture yourself on the side of the rode on I-94 on your way to Rockford with a blown $3 hose. It's all kinds of ugly, expensive, inconvenient, and probably dangerous.
OK Steve, you've convinced me. That journey is a commute to work for me, always involving night driving, and often in cold weather, it's not a joyride.
Yeah, it's a bit more work to do them all, but you can do them in your own space this winter and be done.
Then that's what I'll do.
Also, maybe a thermostat, and for sure a radiator cap. The gasket on the cap will swell causing a higher pressure in your system. Think blown O-rings, hoses, and radiators, oh my.
Ah, I didn't know that about rad cap gaskets.
Murphs' (isn't the apostrophe in the wrong place there? that's how it is on their site) has a set for $60, which I've been told is a better fit than the Kawasaki set (although the brand is shown as Kawasaki on the webpage). Is that the best solution?
A question on coolant temperature: my gauge only ever gets above 1/4 travel when I'm sitting idling at traffic lights. Is that normal, or should it be closer to half way up? Half way is also when the fan comes on periodically, incidentally.
