I set the Connie center stand on a 2"x 6"x 3' long board centered crosswise under the bike. The board has two eye bolts - one on each end. I then tie the handle bars to the eye bolts this secures the bike from tipping over and keeps the bike from rolling off the center stand while tugging on the tires. I also use a 1" x 6" x 12" long board up against the underside of the front of the engine, which spreads out the loads so I don't have to remove the plastic belly pan, and use a small bottle jack to pick up the front of the bike so the tire can clear the finder. This works for front or back. This approach makes it very easy to re-install the tire as you can tweak the jack up or down to the right height to install the spindle bolt without wrestling with the tire height while re-stabbing the bolt. And, as I stated before, you don't need to worry about the bike rolling off the center stand which would ruin your day!
I set one foot of the center stand on a 2x6 by rocking it over to one side and use the heal or toe of my boot to slide it under one foot. Then I rock it the other way and use the heal or toe of my boot to maneuver the board under the other foot. I then tie it down and proceed as described above. When you are finished you can get on the bike and shove it forward off the center stand. HTH JD
JD
P.S. You may have to use a thicker board under the center stand as my bike has been lowered, but you get the idea.
Modify message
