Author Topic: PCV Addition  (Read 2071 times)
Offline jjnorc
  • 2009 C14 Non-ABS. Red.
PCV Addition
« on: July 29, 2013, 01:52:12 PM »
So, I decided to pull the secondary butterflies and add the PC-V.
After reading so many posts on the performance gains, I just couldn't resist.
I have a 2009 B9F, stock exaust, K&N Air Filter.
Ordered the PCV from FuelMoto, told them my setup and asked for a Performance and Economy Map.
The PCV shipped with the Performance Map loaded and I am very happy with the change in throttle response and performance.
I'm going to run a few tanks of gas through with the Performance Map and then try the Eco Map to compare.
I plan on adding the Autotune and an aftermarket exhaust in the near future.
I took some Pics along the way.
Because turning doesn't suck.
Offline jjnorc
Re: PCV Addition
« Reply #1 on: July 29, 2013, 01:54:11 PM »
More Pics:
Re: PCV Addition
« Reply #2 on: July 29, 2013, 06:28:18 PM »
Thanks!  :finger_fing11:
Re: PCV Addition
« Reply #3 on: July 29, 2013, 06:56:26 PM »
More Pics:
If the fuel trim map is realtime, you may want to bump your idle rpm up a bit.
Offline jjnorc
Re: PCV Addition
« Reply #4 on: July 31, 2013, 10:05:01 AM »
Not sure it could be considered "realtime" since I'm not using the autotune.
It's a static map provided by FuelMoto.
The idle RPM is usually 1000 - 1100 which seems to be fine.
