Author Topic: Wrench/Socket sizes needed for a tire change.  (Read 5040 times)
Offline Tele130
« on: May 31, 2013, 07:37:34 AM »
I know I posted this before but being mentally challenged,................ I have a hard time finding my way home from work let alone a post I made 5 months ago ??? ;).
What size of wrenches/sockets do I need?  Front and rear.
Thanks. ;D
Doug Colton
Offline snarf
Re: Wrench/Socket sizes needed for a tire change.
« Reply #1 on: May 31, 2013, 08:44:40 AM »
Front Wheel Removal
Axle clamp (pinch) bolts  8 mm Allen
Axle  12 mm Allen
Brake caliper mounting  12 mm
Rear Wheel Removal Muffler mounting bolts
12 mm
Rear axle nut 27 mm
Brake caliper mounting 8 mm Allen
Final drive removal 14 mm
2002 Conc
1986 Conc "The spirit of COG"
Offline Tele130
« Reply #2 on: May 31, 2013, 08:59:40 AM »
Thanks Chris. :chugbeer:
Doug Colton
Offline snarf
« Reply #3 on: May 31, 2013, 10:42:15 AM »
Any time  8)
2002 Conc
« Reply #4 on: June 01, 2013, 12:30:56 PM »
....Rear axle nut 27 mm
Or a 1-1/16" SAE will work..... ;)  same size....and you might already have one.... ;)
Offline Tele130
« Reply #5 on: June 01, 2013, 02:19:49 PM »
Thanks MOB.  I'll check.  My Connie is buried in the garage somewhere.............My two sons moved back home for the summer (school break) and all their "Stuff" is in there.  Not sure I'll get any saddle time this season.   :o
Doug Colton
Offline Outback_Jon
« Reply #6 on: June 02, 2013, 12:03:26 AM »
Also, depending on the front tire you are removing or installing, a 12mm to remove the front fender bolts.
Offline Summit670
« Reply #7 on: June 02, 2013, 07:40:26 AM »
For the front axle, you can use a metric bolt head if you don't have the proper size allen wrench.  Double nut it.
Years ago I bought a 12mm socket style wrench and the allen part was long enough that I just cut a section off the end to use in the other side and I carry that in my tool kit.
Arctic Cat M8 163 rules
Offline Tele130
« Reply #8 on: June 02, 2013, 10:49:25 AM »
Good point.  When I installed my "GT'S" I found that if I inflate the tire to seat the bead and then deflate it, I could install it without removing the fender.  Those bolts on the INSIDE of the fender are a PITA! ???
Doug Colton
