Please help me again, I'm completely lost!!!
I've been posting on here the last couple of days, and I have another problem... I did a valve adjustment, change spark plugs, took carburetor off to change o-rings on cooling log.
Now it idles perfect, and revs up great in neutral, but when I put it in gear and let out on clutch it dies. If I rev it way up 4k+ it will move but it runs like something is dragging it back. I have a top speed of 65 with throttle wide open. The RPM's stay in the normal range for the speed I'm going.
I took it to a friend's house (he's a car mechanic) we took it back apart, re adjust the valves, put it back together and it still does the same thing.
All the hoses and wiring is connected. Am I missing something?
