Author Topic: Anybody here use a Mojolever to change tires?  (Read 3135 times)
Offline Strawboss
« on: April 08, 2013, 10:23:16 AM »
I got one coming in the mail this week along with the protective Mojo blocks for the HF tire changer, looks like a BIG improvement over the supplied Harbor Freight units. Got all the manuals downloaded and watched the video, its what I already do anyhow. Anybody else here use one, I did a search and it looks like a few do. Comments.
http://home.comcast.net/~prestondrake/mojoweb.htm
« Last Edit: April 09, 2013, 06:41:08 AM by Strawboss »
Re: Anybody here use a Mojolever to change tires?
« Reply #1 on: April 08, 2013, 11:12:43 AM »
looks similar to the No-Mar mount/dismount bar that I use. And if so it is a snap to use as long as the wheel is held firmly. Takes about 10 seconds for each bead to dismount. Spray on some lube, put the nylon end between the wheel and the tire bead, pry up and swing it around. Mounting takes a little more but still once you get the knack it is about a 1 min to put the tire back on.
Offline 1 wheel peel
« Reply #2 on: April 08, 2013, 02:44:59 PM »
I have the Mojo and the NoMar, use the Mojo probably 90% of the time.  Dismount is the same for either, Mojo is a little longer.  The mounting is a little easier due to the way the end of the Mojo is manufactured in *most* applications IMO.
Offline redzgrider
« Reply #3 on: April 08, 2013, 06:28:28 PM »
Well that's good news! I've had a Mojo and blocks for a while now, just looking for a spot to mount the machine.
Offline Strawboss
« Reply #4 on: April 09, 2013, 06:42:03 AM »
Thanks, just looks so much easier than the HF POS lever. No scuffs too!
Offline kzz1king
« Reply #5 on: April 09, 2013, 04:15:45 PM »
What HF tire changer are you using? Is the mc adapter for it still available?
Wayne
2010 CONCOURS
1974 Z-1
Offline redzgrider
« Reply #6 on: April 09, 2013, 05:01:00 PM »
HF dropped both the tire machine and the motorcycle adapter about two years ago. They brought the tire machine back late last year, but still haven't brought back the MC adapter. I found a used one on Craig's list for pretty much what used to be HF's full price...
Offline Steve in Sunny Fla
    • Shoodaben Engineering
« Reply #7 on: April 10, 2013, 06:02:10 AM »
I have the mojo lever and blocks. Radial tires are a snap, some bias, like the pilot gt's, not so much. Steve
Offline Strawboss
« Reply #8 on: April 10, 2013, 09:57:10 AM »
Thanks all, I just got my stuff in the mail, got to wait for it to warm past 45 degrees! I'll keep you all posted.
« Reply #9 on: April 10, 2013, 11:01:54 AM »
Lots of good instructional videos on the NoMar website for anyone interested.
http://www.nomartirechanger.com/Articles.asp?ID=256
