Author Topic: Replacement key blanks  (Read 3598 times)
Offline 4cedars
« on: August 26, 2011, 03:13:30 PM »
I did a search and apparently there is nothing on the new site about this yet. Does anyone remember the Ilco key model # for getting keys cut. The local key cutter I went to had Hillman key blanks and did not have the correct blank for the connie. He only had 1 listing for Kawasaki in general. I remember on the old site there was a very in depth thread.  Thanks, John
IBA# 45862
MTF Tourers Assistant
Re: Replacement key blanks
« Reply #1 on: August 26, 2011, 03:19:07 PM »
From the forum that is COG...
Keys
Key Blank - ILCO KW14R  Note: Double check your keys and this information. There seems to be two types of keys, beginning with either an "A" or "B". If you have an "A" key it should be a "KW14R" key-blank.  If you have a "B"  key, it should be an "KW14" key-blank. This was true on the 2008. But I'm not sure how they may be on newer models (so double check).
 http://www.mysecuritypro.com/index.asp?PageAction=VIEWPROD&ProdID=663
Offline So Cal Joe
« Reply #2 on: August 26, 2011, 03:43:24 PM »
I went to a lock smith and he had the blank.
Offline 4cedars
« Reply #3 on: August 26, 2011, 08:31:56 PM »
Thanks Brent
IBA# 45862
