Author Topic: Decal removal  (Read 3153 times)
Offline wahrsuul
  • This is personal, stop reading it!
Decal removal
« on: February 25, 2013, 12:24:09 PM »
Ok, I've seen threads on how to debadge the tank, but nothing about how to remove the big vinyl "decal" on the lower fairing and side covers.  I want to paint the bike, and need to get that off.  Sand it off?  Heat?
1999 C-10: Knee savers, Givi trunk, Rifle windshield, KB risers, K&N...and counting...
What did I do to deserve this life?  And how do I do it again?
Offline Walker18
Re: Decal removal
« Reply #1 on: February 25, 2013, 01:43:02 PM »
Are these decals put on by the previous owner? Anycase, try this.
If you can get a corner up a little, use 'GOO GONE', it dissolves the adhesion compound. Might take a little time, but no marks will be left.
COG#8443
AMA# 1088783
2012 C-14  'Rudy'
Offline Bikenagain
Re: Decal removal
« Reply #2 on: February 25, 2013, 10:41:04 PM »
Gently with a heat gun
Offline wahrsuul
Re: Decal removal
« Reply #3 on: February 26, 2013, 08:03:45 AM »
These are the factory lower color decal is all I can think to call it.
Re: Decal removal
« Reply #4 on: February 26, 2013, 09:01:04 AM »
^^^^^that.  and after i remove it I usually clean residue area with some goo gone such as a gentleman above mentioned
Offline Roadhound
Re: Decal removal
« Reply #5 on: February 26, 2013, 10:49:28 AM »
The factory did not use any decals on the bike. The area you are speaking of is painted, unless a PO added some vinyl stick ons to the bike. If you are going to repaint, all you need to do is sand it.
Don Ricks
Atlanta, Ga.
Offline qman
    • Autobahn Motors
Re: Decal removal
« Reply #6 on: March 06, 2013, 08:51:38 PM »
heat gun or hair dryer to lift, goo gone to get rid of the residue
Re: Decal removal
« Reply #7 on: March 17, 2013, 03:11:20 PM »
if you are talking about the trim pinstripes, those are actual thin tape, which was applied before a clearcoat was applied....virtually impossible to remove nicely. You end up having to sand the clearcoat and tape down, and then scrape the tape off....and feather all the edges with wet sanding....a royal P.I.T.A.
went thru it during the COGZilla buld, it had the pinstripes....arggggg. :'(
with that said, your sig shows you have a 1999, it had no such stripes, or decals, only factory "stickers" which peel off with a heatgun, or hairdryer heat.
