Author Topic: Fork pre-load tool  (Read 2271 times)
Offline timsatx
Fork pre-load tool
« on: November 24, 2012, 11:29:10 AM »
Does anybody have any good suggestions for a tool to adjust the fork pre-load? Preferably something better than a pair of pliers but without spending a lot coin.
Offline Rick Hall
  • Eruption
Re: Fork pre-load tool
« Reply #1 on: November 24, 2012, 12:14:09 PM »
10mm open end wrench?
Rick
Offline gtr1000
« Reply #2 on: November 24, 2012, 01:01:07 PM »
Paul OTP (near Windsor, GB).
06 C-10, 2009 to .....
A5 C-10, 2000 to 2009.
Offline timsatx
« Reply #3 on: November 26, 2012, 09:44:26 AM »
When I took off my handlebars I used the 10mm wrench. It worked okay but if I want to adjust it with everything together it seems like it would be a pain.
Offline Outback_Jon
« Reply #4 on: November 26, 2012, 09:56:14 AM »
I'm guessing you have risers installed.  Without the risers, a 10mm wrench works just fine.  With risers, like I have, I still use a 10mm wrench, but have to carefully count the turns I make, since I can't see the lines on the sides of the adjusters.
Offline timsatx
« Reply #5 on: November 26, 2012, 10:05:03 AM »
That's affirmative.
Offline Silverado
« Reply #6 on: December 13, 2012, 09:33:25 PM »
I made a tool out of 1/2" copper tubing and fittings.  I used a "t" fitting for the handle attached to an 8 inch section.  I notched out a cap on the end of the 8 inch section approximating a 10mm wrench.
« Last Edit: December 18, 2012, 07:18:33 PM by Silverado »
Offline timsatx
« Reply #7 on: January 10, 2013, 10:08:39 PM »
I guess it has been awhile since I have been in this forum. I didn't realize I had a new post in this thread. That sounds like a great idea Tony.
