Author Topic: Second TPS battery warning  (Read 10115 times)
Re: Second TPS battery warning
« Reply #20 on: December 23, 2012, 11:40:02 AM »
Some good ideas there Max...how about solar powered?
That too, damnit!
Offline texrider
« Reply #21 on: December 24, 2012, 09:45:23 AM »
My sensors have been temp sensitive for a while now, and took a few miles to wake up. Last ride I got the LO BATT warning from the rear sensor, and had to clear the screen every time. Looks like I'll be attempting to solder in new batteries at next tire swap.  :(
2014 Valkyrie
Offline JerBear
« Reply #22 on: December 24, 2012, 12:12:11 PM »
Assuming I don't want a tpms will the wanting go away or stop all together when the batts die completely?  Can they be removed to get rid of it sooner?  Mine are 4 years old and cold mornings it take alot of warming for them to clear and the two button push in a pain with gloves on.  I don't really want or need tpms so if it goes away I'm headed that way.
2008 C14 Non-ABS
« Reply #23 on: December 24, 2012, 12:19:30 PM »
Once the battery dies, then the warnings go away.
Offline Scaffolder
« Reply #24 on: December 24, 2012, 04:17:51 PM »
And then
Joel from Maine.
Offline c1obrien
« Reply #25 on: December 29, 2012, 08:53:08 AM »
I replaced a TPS battery yesterday with help from this forum, and it was easier than I thought. I haven't had a chance to test it yet as I'm waiting for new 90 degree valve stems, but I can see no reason it shouldn't be just fine..  Here are some pics:
chip
« Reply #26 on: December 29, 2012, 09:05:02 AM »
Thanks for posting. It looks like you unsoldered the old battery from the tabs and soldered the tabs to the new battery? Were you worried that the heat would damage the new battery?
Offline c1obrien
« Reply #27 on: December 29, 2012, 09:12:11 AM »
I was aware of the danger, so the new battery was no where near the area being soldered. I bent the metal connectors so they put pressure on the battery for a solid connection.
chip
« Reply #28 on: December 29, 2012, 09:29:58 AM »
chip
So the new battery is NOT soldered. Hopefully vibration will not be a problem. I bought some batteries that have tabs but they are not ideally positioned and I have not decided yet wether to use them. I will be eager to hear about your test ride.
Offline c1obrien
« Reply #29 on: December 29, 2012, 09:33:46 AM »
No, I did not solder the battery. There isn't much room for it to move where it is, plus there's that little yellow "spring" thing that presses down on it. It's crunched in there pretty tightly!
« Reply #30 on: December 29, 2012, 09:34:26 AM »
