If there is a 2 ohm voice coil speaker in there now, any other 2 ohm voice coil speaker will not hurt the amplifier. I guess the japs think the laws of science do not exist in the USA. ohms law: E=I X R guarantees no extra current will be drained from the output transistors.
There is a company in Kokomo, IN that actually rebuilds high end speakers where the cones have seperated. They have customers from around the world.
I had an old set of Marantz speakers in the house where the suspension foam started to deteriorate on the 12 " woofers. They still sounded great. I used silicon based glue and gently brushed a "patch" over the sections that started to split. Over the course of 5 years, I kept patching until the entire foam suspension had become a silicon glue membrane. If your speakers still have the voice coils in alignment around the magnet, I am sure the kit will work for you, as it installs over what is left. Good Luck
